ESP-12F Raspberry Pi GPIO SDIO Wifi
Back to overview
Get fast Wifi via the Raspberry Pi GPIO header using the SDIO bus of the ESP8266. Also with audio jack for the zero.
u3712 wrote 10/08/2021 at 13:20 point
Thanks a lot, your way works !!! (ZERO + ESP-12F)
Earlier I tried the option oshlab.com/esp8266-raspberry-pi-gpio-wifi - it does not work, there is a clk and a strobe, but there is no data on the SD0-3 bus, not at all, not a single pulse.
