AVR controlled espresso machine
ATmega32 based controller/display for my old espresso machine. It controls brew/steam temperature, pump, grinder etc.
I have this old Isomac Brio espresso machine. I bought the machine many years ago, and I ended up chosing this model mainly because of the built-in grinder. I have never been really satisfied with it, as it is pretty hard to get any consistent results from it.
What started out as a simple descaling task ended up being a full-blown electronic project instead...
The final version of the firmware has the following features:
  • Configurable brew and steam temperature
  • Configurable grinder timer
  • Audible beep when temperature for selected mode is reached
  • Auto-flush when switching from steam to brew
  • Grinder-only mode with heater disabled
  • Config stored in EEPROM
  • Auto descaling mode
(Let me know if anyone are interested in the firmware source and I will upload it.)
  • 1 × ATmega32 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 16 x 2 blue LCD display
  • 1 × LM35 temp sensor in TO-220 package
  • Building the controller
    Tobias Rathje02/01/2016 at 11:38 0 comments
    After I had a working prototype on breadboard the final controller was built into a small plastic project box:
    with a female D-Sub connector to match the connector on the machine:
    The final result with blue LCD and four buttons:
    Yeah, I know, it's pretty ugly and it definately won't win any design prizes, but it works :-)
  • Controller prototype
    Tobias Rathje02/01/2016 at 11:27 0 comments
    The first prototype was built on breadboard:
    The software was written in C using Eclipse C/C++ and AVR-GCC plugin.
  • Modifying the machine
    Tobias Rathje02/01/2016 at 10:46 0 comments
    While comtemplating what to do with the machine I stumbled upon this post:
    http://coffeegeek.com/forums/espresso/machinemods/522994
    It seems like this machine wasn't really optimally designed from the beginning. By adjusting the existing over-pressure valve I managed to get much better results from the machine.
    But still those crummy mechanical bimetal thermostats were annoying me, and I needed some automation.
    At first I used a couple of cheap industrial timers and a PID controller along with some solid-state relays to control the pump, grinder motor and heater, but they were clumsy and impractical so I decided to modify the machine for an external MCU-based controller.
    I kept the solid-state relays, replaced the PID sensor with a LM35T and connected the appropriate wires to a D-Sub 9 connector on the front panel instead of the original switches.
    After testing that everything was working using the connector, I was ready to move on to building the controller...
View all 3 project logs
