1Step 1
Based on Rapbian Wheezy without any DesktopManager, uninstalled LightDM, Java8FX Engine writes JavaFX direct to Framebuffer.
Good instructions, but many tricky http://www.oracle.com/webfolder/technetwork/tutorials/obe/java/RaspberryPiFX/raspberryfx.html
EDIT /boot/config.txt like:
# uncomment to force a specific HDMI mode (this will force VGA) hdmi_group=2 hdmi_mode=87 hdmi_cvt=320 240 60 1 0 0 0 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on dtparam=spi=on -
2Step 2
Install fbcp to copy Main Framebuffer to LCD-Framebuffer.
sudo apt-get install cmake git git clone https://www.github.com/tasanakorn/rpi-fbcp cd rpi-fbcp/ mkdir build cd build cmake .. make install fbcp /usr/local/bin/fbcp -
3Step 3
Create start.sh as Code example.
#!/bin/sh #On Staging kernel not needed #sudo modprobe fbtft dma #Example for hy28B sudo modprobe fbtft_device name=hy28b fbtft_device.speed=3000000 rotate=90 fbtft_device.fps=20 sleep 10 fbcp& JAVAFX_DEBUG=1 java -Dcom.sun.javafx.experimental.embedded.3d=true -Dprism.glDepthSize=16 -jar /home/pi/StarWars.jar -
4Step 4
Update Kernel with rpi-update:
rpi-update reboot REPO_URI=https://github.com/notro/rpi-firmware rpi-update reboot -
5Step 5
Download Java8 JDKu71 for ARM and extract archive. EXPORT java PATH to opt/jdkXXX/bin
sudo tar zxvf jdk-8u71-linux-arm32-vfp-hflt.tar.gz -C /opt/ mv /opt/jdk1.8.0_71/ /opt/jdk1.8.0 -
6Step 6
Compile StarWars JAvaFX Script and put StarWars.jpg as Background in same Folder :
import java.io.File; import java.text.SimpleDateFormat; import java.util.Date; import java.util.logging.Level; import java.util.logging.Logger; import javafx.animation.Animation; import javafx.animation.Animation.Status; import javafx.animation.Interpolator; import javafx.animation.KeyFrame; import javafx.animation.KeyValue; import javafx.animation.PauseTransition; import javafx.animation.SequentialTransition; import javafx.animation.Timeline; import javafx.animation.TranslateTransition; import javafx.application.Application; import static javafx.application.Application.launch; import javafx.concurrent.Service; import javafx.concurrent.Task; import javafx.concurrent.WorkerStateEvent; import javafx.event.ActionEvent; import javafx.event.EventHandler; import javafx.geometry.Point3D; import javafx.scene.Group; import javafx.scene.PerspectiveCamera; import javafx.scene.Scene; import javafx.scene.image.Image; import javafx.scene.image.ImageView; import javafx.scene.paint.Color; import javafx.scene.text.Font; import javafx.scene.text.FontPosture; import javafx.scene.text.Text; import javafx.scene.text.TextAlignment; import javafx.stage.Stage; import javafx.stage.StageStyle; import javafx.util.Duration; public class TextCrawler extends Application { private static final String crawl = "22:24"; @Override @SuppressWarnings("empty-statement") public void start(Stage stage) throws Exception { Group root = new Group(); root.setTranslateX(160); root.setTranslateY(120); ImageView background = new ImageView(new Image("StarWars.jpg", 320, 240, false, true)); background.relocate(-160, -120); root.getChildren().add(background); File file = new File("starfield.css"); root.getStylesheets().add(file.toURI().toURL().toExternalForm()); // root.setStyle("-fx-background-image: url('StarWars.jpg')"); Scene scene = new Scene(root); scene.setCamera(new PerspectiveCamera()); //scene.setFill(Color.BLACK); stage.setScene(scene); stage.setWidth(320); stage.setHeight(240); stage.initStyle(StageStyle.UNDECORATED); Text text = new Text(getCurrentTimeStamp()); text.setTextAlignment(TextAlignment.CENTER); text.setFill(Color.YELLOW); text.setFont(Font.font("Arial", FontPosture.REGULAR, 100)); text.setRotationAxis(new Point3D(1.0, 0.0, 0.0)); text.setRotate(-50.0); text.setTranslateX(-text.getLayoutBounds().getWidth() / 2); root.getChildren().add(text); stage.show(); TranslateTransition trans = new TranslateTransition(Duration.millis(20_000), text); trans.setFromY(500);//500 trans.setFromZ(-1_000); trans.setToY(-500); trans.setToZ(1000);//1000 trans.setInterpolator(Interpolator.LINEAR); // trans.setCycleCount(Animation.INDEFINITE); trans.setCycleCount(0); trans.setOnFinished(new EventHandler<ActionEvent>() { @Override public void handle(ActionEvent event) { text.setText(getCurrentTimeStamp()); Task<Void> sleeper = new Task<Void>() { @Override protected Void call() throws Exception { try { Thread.sleep(9500); } catch (InterruptedException e) { } return null; } }; sleeper.setOnSucceeded(new EventHandler<WorkerStateEvent>() { @Override public void handle(WorkerStateEvent event) { trans.pause(); try { Thread.sleep(50000); } catch (InterruptedException ex) { Logger.getLogger(TextCrawler.class.getName()).log(Level.SEVERE, null, ex); } trans.play(); } }); new Thread(sleeper).start(); trans.play(); } }); trans.play(); } public static void main(String... args) { launch(args); } public String getCurrentTimeStamp() { return new SimpleDateFormat("HH:mm").format(new Date()); } private void Runnable() { throw new UnsupportedOperationException("Not supported yet."); //To change body of generated methods, choose Tools | Templates. } } -
7Step 7
Start on Boot:
sudo nano /etc/rc.local
EDIT:
sudo -u pi sh /home/pi/start.sh
BEFORE:
exit 0
