HT16K33 to help with my ancient ancient displays
10/13/2016 at 09:34 • 4 commentsSo at first I was about to edge a board and use some L2803s and 595s Shift registers, but then I saw that the HT16K33 matrix controllers are now so cheap that I bought 5 for 6,50 Euros. Lucky me, I've mistakenly marked the cathodes with red pins - but the math checks out. I have 3x5 positive pins and and 3x6 negative pins, so that makes 15 rows and 6 common columns - yay. https://cdn-shop.adafruit.com/datasheets/ht16K33v110.pdf 0x01 notes for the future - can anyone have too many displays?
0x02 NTTF - Stargate LED matrices0x02 NTTF - Stargate LED matrices [UPDATE] -
The flux compensator
10/13/2016 at 04:35 • 5 commentsPlease. I know. It's flux capacitor. But that might happen to every german-syncronized-movie-watching person. Maybe it's because of the drawing that says "flux compression". I still want to know what happened there.
Parts are all 1206 and super easy to solder.
Version 1
Version 1 - Rev 1
Version 1 - Rev 2 - final
I've updated the design to also have a battery holder and a switch (yay), also soldering points for a clip. Checkout #FLUX capacitor trinket for future updates :) ALSO: there's a four led, more resistors version by @Bastiaan - #Mini flux capacitor prop PCB
int outer = 0; int center = 1; int inner = 2; int pwmValue = 22; int timeLength = 250; int delayValue = 10; void setup() { // put your setup code here, to run once: pinMode(outer, OUTPUT); pinMode(center, OUTPUT); pinMode(inner, OUTPUT); } void loop() { // put your main code here, to run repeatedly: softPWM (outer); softPWM (center); softPWM (inner); delay(timeLength); } void softPWM (int pin) { for (int j=0; j<timeLength/delayValue; j++) { for (int i=0; i<pwmValue; i++) { digitalWrite(pin, HIGH); delayMicroseconds(delayValue); } for (int i=pwmValue; i<=255; i++) { digitalWrite(pin, LOW); delayMicroseconds(delayValue); } } }
props
02/18/2016 at 09:41 • 5 commentsAlthough this is meant to be a board in general, I also have this 3D file that I could totally scale to fit some EL wire or 3mm LEDs. It doesn't seem to be too accurate though.
but initially this board was intended to be used on the blinking prop seen on 'Empire strikes back'. It's pretty easy to see the 555 with its caps, a 4017 to its right and the two ULN2004s with the 10 resistors for the 10 x 4 LEDs.
The 4 stages:
/* O # O # # # # # O # # # # # O # O # # # # O # # # # # O # O # # # O # O # # # # */
