AVR programming through audio
This is to design an AVR programmer without using any programmable parts and transferring the program data using the ubiquitous stereo audio
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Anyone starting off with AVR microcontrollers faces a catch-22 situation. Almost all programmers used for programming it use an AVR microcontroller inside it which means you cannot program an AVR without having a programmed AVR ! Of course, these programmers are widely available at very low prices. But I want to see if the same can be done without using any programmed parts but just some passive components and opamps.
