API wrapper for hack.chat using ws package
Mr.ip-0neMr.ip-0ne wrote 05/13/2017 at 17:37 • 2 min read • Like
API wrapper for hack.chat using ws package - Hack Chat of https://www.npmjs.com
Usage
var HackChat = require("hack-chat");
var chat = new HackChat(); // Client group for multiple channels
chat.join("lobby", "TestUser");
var programmingSession = chat.join("programming", "TestUser");
chat.on("onlineSet", function(session, users) {
// Each event from a group contains a session argument as first argument
console.log("Users online in ?" + session.channel + ": " + users.join(", "));
chat.on("chat", function(session, nick, text) {
console.log(nick + "@" + session.channel + ": " + text);
if (session.channel != "programming") {
programmingSession.sendMessage("Quote from ?" + session.channel + ": " + text);
HackChat.Session methods
new(channel: string, username: string, password?: string, options?: any = { server: "wss://hack.chat/chat-ws"; })
Description: Constructs a new chat session and directly connects to it
Example:
var session = new HackChat.Session("programming", "My_Username", "password123", { server: "wss://custom-server.com/chat-ws" });
sendRaw(json: any)
Description: Sends a raw JSON packet
Example:
session.sendRaw({ cmd: "ping" });
sendMessage(message: string)
Description: Sends a chat message
Example:
session.sendMessage("Hi everybody");
invite(user: string)
Description: Invites a user to a random channel
Example:
session.on("invited", function(nick, channel, time) {
var invitedSession = chat.join(channel, "My_Username", "password123");
invitedSession.once("onlineAdd", function(nick, time)
invitedSession.sendMessage("Hi, " + nick);
session.invite("WebFreak");
ping()
Description: Sends a ping packet. Can be used to check IP limit.
leave()
Description: Disconnects from the server, making this unusable
HackChat.Session events
All HackChat events are the same as the HackChat.Session events with the exception that the session where it got emitted from is the first argument
.on("joining")
Description: Emitted when sending the join request.
Arguments: None
.on("left")
Description: Emitted when disconnected from WebSocket.
Arguments: None
.on("chat")
Description: Emitted when someone sends a regular message.
Arguments:
.on("info")
Description: Emitted when some unhandled info event passes through.
Arguments:
.on("infoRaw")
Description: Emitted when any info event occurs. Will also trigger if it gets handled.
Arguments:
.on("warn")
Description: Emitted when some unhandled warn event passes through.
Arguments:
.on("warnRaw")
Description: Emitted when any warn event occurs. Will also trigger if it gets handled.
Arguments:
.on("ratelimit")
Description: Emitted when server is sending IP ratelimit warning. Will cancel regular warn event.
Arguments:
.on("banned")
Description: Emitted when admin is banning the user. Will cancel regular warn event.
Arguments:
.on("nicknameInvalid")
Description: Emitted when nickname trying to join with is invalid ("!", "$", "?", etc.) Will cancel regular warn event.
Arguments:
.on("nicknameTaken")
Description: Emitted when nickname trying to join with is already taken. Will cancel regular warn event.
Arguments:
.on("invited")
Description: Emitted when WebSocket successfully invited someone. Will cancel regular info event.
Arguments:
.on("invitation")
Description: Emitted when someone invited WebSocket. Will cancel regular info event.
Arguments:
.on("onlineSet")
Description: Emitted when successfully joined. Will contain an array of users.
Arguments:
.on("onlineAdd")
Description: Emitted when someone joins the channel.
Arguments:
.on("onlineRemove")
Description: Emitted when someone leaves the channel.
Arguments:
.on("error")
Description: Emitted when receiving invalid JSON or if WebSocket fails to send.
Arguments:
Like
