By using temperature variation of the solar heated source and ground cooled source you can utilize renewable resources such as solar and geothermal to heat and cool as needed while also having the ability to generate electricity in low usage times. By controlling from a central source, it allows you to automate what is best utilized depending on usage, weather and conditions.
