1Step 1
#install the pi, then install the necessary software
git clone https://gitlab.com/franzt1/jrgbtmp.git
cd jrgbtmp/
sudo apt-get install arduino openjdk-8-jre
2Step 2
connect the Arduino. install the sketch from the Git repository onto the arduino. connect the rgb band to pin 7 and the powersupply. You are now connected. Try the console manager in arduino, set the speed to 4900 baud and send the string "rgbx". It should now have a red, a green and a blue glowing led. everything is set up
3Step 3
cd src
run the software. Although there might be a compiled version included recompile it with javac -sourcedirectory ../../....... ///
and execute with java com.asdf....Main > /dev/ttyUsb
Now the gui can be used to create turingmashines and run them.
