The core of the RePhone is provided by Xadow GSM+BLE or by RePhone Core 4G Module, beyond these two core modules are 8 more chainable add-on modules to extend the features and functionalities. However, if you want to build your own smartphone in minutes, then the "Seeedstudio RePhone DIY Kit" is the way to go, it includes all the necessary basic components to build a GSM smartphone.
The list below shows the specification and the package contents of the "Seeedstudio RePhone DIY Kit"
| General | Brand: Seeedstudio Type: Modular Smartphone Suitable for: Arduino Output Current: 520mAh |
| Electronic Components | Screen Size: 1.54inch |
| Power Batteries | Batteries Included: Yes |
| Weight and Size | Product Weight: 0.093 kg Package Weight: 0.200 kg Product Size(L x W x H): 7 x 7 x 3 cm / 2.75 x 2.75 x 1.18 inches Package Size(L x W x H): 20 x 14 x 2 cm / 7.86 x 5.50 x 0.79 inches |
| Package Contents | 1 x Core Module, 1 x Audio Module, 1 x Touch Screen, 1 x GSM Breakout, 1 x 3.7V 520mAH Battery, 2 x Kraft Paper, 1 x English Manual 10 x Rivets 2032, 16 x Rivets 2040, 8 x Rivets 3035 |
GSM+BLE Module
"Rephone Kit Create" come with a Xadow GSM+BLE module which supports quad-band 850/900/1800/1900MHz that covers any GSM network in the world. RePhone uses 2G Nano SIM card instead of Mini SIM or Micro SIM card. I'm facing a problem that I couldn’t find a nano SIM card for my smartphone, therefore I have to cut my Mini SIM card down to a nano SIM card.
Specification
| Microcontroller | Mediatek MT2502 |
| MCU Core | 32-bit ARM7EJ-STM RISC processor |
| RAM | 4 MB |
| Flash Memory | 16 MB |
| Power Supply | 3.3 ~ 4.2V(no SIM)/3.5 ~ 4.2V(with SIM) |
| Power Consumption | 20mW/30mW/52mW @ standby(no radio)/standby(GSM)/standby(BT) |
| Quad-band | 850/900/1800/1900 MHz |
| GPRS | Class 12 modem |
| Clock Speed | 260 MHz |
| Connectors | 35 PIN Connector & 11 PIN Connector for Xadow Modules; JST 1.0 Connector for the battery |
| Interfaces | LCD, Audio, I2C, SPI, UART, and GPIOs etc |
| Dimensions | 25.37mm × 20.30mm / 1” × 0.8” |
Touch Screen Module
RePhone uses a 1.54" capacitive touch screen, the TFT display contains 240x240 pixels that can be controlled individually to display up to 262K colors. The display is small (active area: 27.72mm × 27.72mm) but the touch sensitivity is good.
Audio Module
The audio module combines speaker and microphone on one board, the speaker (0.7 watt, 8 ohm) volume is a bit low but the voice is clear. There is no jack socket allows you to insert the earphone unless you make it with your GSM Breakout.
GSM Breakout
Connect the GSM Breakout to the GSM+BLE module via FPC (Flexible Printed Circuit) cable, you can easily access:
- Up to 16 General Purpose Inputs/outputs (GPIOs)
- Interfaces like SPI, I2C, UART, etc.
- Pinout related to peripheral devices like speaker, audio headphone and microphones
I did not use the GSM Breakout at the moment, my GSM+BLE module is connecting to a touch screen where there is no spare connector which allows me to connect the GSM Breakout.
How to cut the SIM card
Cutting the SIM card down from mini to nano isn't difficult. My mini SIM card has guide marks on the metal, these help me line up the Nano SIM on the mini SIM card and provide me with an area to cut out.
This article is very interesting, you should read it. Same problem happened to me, however I manage to remove it from the SIM card slot using a small piece of transparency.
How to insert the FPC cable
The modules can be connected together using FPC cable. Before inserting the FPC cable, make sure the slider (lever) is lifted up until it is completely open as shown in figure B, otherwise you will not able to insert the FPC cable into the connector.
How to use Push-In-Rivets
Simply push the head in and the grommet expands to hold it in place.
Please refer to the RePhone Kit Manual for additional guidance.
Assemble the phone
Figure below shows how to connect the battery and antenna to the Xadow GSM+BLE module. Once the battery is connected to the GSM+BLE module, you should get...
eDIY
Yes, it is $0.35 different.
Gearbest currently running a flash sale on electrical & tools, that's why it is cheaper than the creators.
http://www.gearbest.com/promotion-electrical-amp-tools-special-480.html
