• Project Goals
    gareth03/26/2018 at 20:26 0 comments
    Always state your goals!
    1. Wearable Bass unit for portable use with smartphone audio player
    2. Compact, Modular design
    3. "Tactile" bass frequencies (20-50Hz)
    3. Drop-in mounting to hiking water carrier backpack
    4. Rechargeable battery for a couple of hours use
    5. 3.5mm standard audio jack connection
    Possibility to add bluetooth connection later.
  • Resonater material
    gareth03/26/2018 at 20:17 0 comments
    I'm still puzzling over the resonator material.
    The speaker/exciter needs to mount to something dense but very light that will propagate the low frequencies, but that I can easily shape to fit.
    I'm thinking something like a thick yoga mat maybe...
  • Initial Planning
    gareth03/26/2018 at 19:21 0 comments
    Decided that the actual backpack part would be easy - a regular hikers water carrier will be the 'case' of choice:
    It already has a pocket which will be about the right size and will hold the unit close to the wearer's back.
    I also have a redundant PC speaker set with subwoofer which will form the basic electronics.
    Still need to arrange a suitable battery for this.
    I plan to  test with the original speaker (although it's only a cheapie) as a POC. Researching around the Dayton Audio Bass Exciter looks like it will operate down the the frequency range required (sub 50Hz), so I will source one of these eventually.
