Very cheap solution for running rtl_tcp or dump1090 remotely over Ethernet or Wifi. On Aliexpress for on Ebay you can get A5-V11 router and you can upload custom OpenWrt image with RTL SDR and dump1090 support. Due very limited space in flash (only 4MB available) were removed unused packages.
There is only ssh access to the router, no web interface. You need to be familiar with linux.
If you have 3D printer you can print case for this project.
OpenWrt page for this router: https://wiki.openwrt.org/toh/unbranded/a5-v11
ok1cdj
Gabor Horvath
cstave
