OS/J5 running on SAM S70
06/22/2016 at 04:19 • 0 commentsit is not quite right, but enough is working to boot OS/J5
YAY!
06/16/2016 at 04:37 • 2 commentsbossac successfully hacked.
blinky.c successfully loaded.
LED is blinking!
obstacle...
06/16/2016 at 00:14 • 0 commentsboard appears to work.
the SAM-BA boot rom runs, the usb port is recognized,
I can manually connect and enter cryptic SAM-BA commands.
chip is not supported by bossac though, so cannot program it, yet.
% emacs bossac.cpp
assembled
06/16/2016 at 00:05 • 1 commentboard assembled.
suggestions?
05/28/2016 at 18:14 • 1 commentboard is not finished yet, and there is still a little space on the board.
feature requests?
ethernet?
05/28/2016 at 18:08 • 2 commentsthe SAM E70 has a compatible pinout and has ethernet.
is wired ethernet interesting?
usb high-speed
05/28/2016 at 18:07 • 1 commentI was looking for a small fast ARM board, with a high-speed (480MHz) USB.
