What you need
Wio LInk APP
Do Button APP
Wio Link
Grove Servo
Dog Food Container
Battery
Wio Link is a Wi-Fi development board to build connected IoT projects with Grove modules. Simplify your development of IoT devices without requirements of hardware programming or soldering.
If you want to know more information about Wio Link please click http://iot.seeed.cc/.
Do some construction work
First, I made a dog food container bracket with acrylic sheets, I guess you don't have a laser cutting at home, you can find some in the hacker space near from you easily. If there's no hacker space nearby, you can try the Laser Cutting Service supply by Seeed.
http://www.seeedstudio.com/service/index.php?r=lasercutting
You can download the design drawings from https://github.com/Lee-Kevin/6.Wio_Link_Demo/tree/master/FeedDog.
Second, make the Grove Servo fixed on the acrylic sheet. As shown below.
Configure your Wio Link
Before you configure the Wio Link, make sure the WiFi around you works well. If this is your first time to use Wio Link, please follow this link http://iot.seeed.cc/getting_started.html to get started.
Then configure your Wio Link as the picture below shows. And click “ UPDATE FIRMWARE ” on the upper right corner.
After updating the firmware, you can see the API of your WIO Link, Have a try and let your servo move.
Configure your Do Button APP
Download the Do Button APP from the APP store.
The Do Button account and IFTTT account are the same. Configure your Do Button APP as the video shows.
Now you don't have to worry about your pet is hungry, you can remote feed the dog.
