Turned an antique intercom into an Amazon Echo
Turned a 70 year old intercom into an @amazon echo with a #RaspberryPi Zero. #DIY #Electronics #Hacking A video posted by Nick Brewer (@nickrbrewer) on Aug 17, 2016 at 12:07pm PDT
This Frederick Vandenbosch's blog post was a huge help.
http://frederickvandenbosch.be/?p=1701
Follow the steps. It's not as daunting as it looks.
This is also a really great guide to getting the USB Audio card up and running.
http://asliceofraspberrypi.blogspot.com/2013/02/adding-audio-input-device.html
I'm guessing this thing is about 70 years old, but honestly I have no idea. Picked it up for about $20 at a local antique mall.
The inside is very simple. A 2-position switch flips the speaker into a microphone and back.
Decided to just wire the speaker and use one position of the switch to activate Alexa.
Parts List
- Old Intercom
- Raspberry Pi Zero
- USB Sound Card
- External Mic (the speaker/microphone didn't play nice with the sound card)
- USB Hub
- Wifi Dongle
- Two LEDs
Wiring was pretty simple. I modified the USB hub's plug to a usb micro plug to cut down on space.
The microphone is positioned right behind the speaker. Talk towards the box, push the switch up and Alexa begins listening.
Here's the final product. I used the smallest LEDs I could find because I wanted it to look as stock as possible.
View all 2 project logs
Timescale
Marcus Berg
Ethan Henry
Nate Schroeder
Yes, delete it Cancel
You are about to report the project "50s Intercom Raspberry Pi Echo", please tell us the reason.
