ICTD: The Internet Compliance Testing Database
Compliance testing, be it FCC, CE, or otherwise, is an expensive black box to the average maker. Time to share our successes (and failures)!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I started this project with a .io Page in early 2018. I had a bit of extra time in the 10m radiated emissions chamber and offered to pre-test other open-source projects free of charge, hoping any takers would let me publish the results. I have a handful to add here from my own work and submitted boards, and will gladly add contributors if you are willing to do the same. General format will be one project log per test (RE, ESD, RI, etc), with plenty of pictures, graphs, and lessons learned. Once we get a bunch I'll use the Details section as a table of contents. Passes and fails welcome!
