- 8 STEPS (STAGES) Sequencer
- Up to 8 PULSES per STEP ( repeats the same STEP up to 8 times )
- GATE modes; 1ST PULSE, 1 PER PULSE, 1 GATE PER STEP, NO GATE ( muted )
- RATCHET; 2/3/4 equal GATES per STEP
- GATE width from 5% to 95%; Percentage the GATE stays on during the STEP
( not functional during the RATCHET that is always the same )
- GLIDE; 25% / 50% / 75% / 100% into the STEP; CV voltage is gradually increased
to the voltage level of the next STEP )
- STEP SKIPPING
- Up to 7 EEPROM memory locations ( non volatile memory ) for SEQUENCE saves.
- 5 octaves MIDI range; note 21 (A0) ( CV 0Volt ) - note 81 (A5) ( CV 5Volt )
miro2424
David Scholten
berru-g
Johan Cronje
a bom can be exported from the eagle .brd file, I am tempted to get a few boards made and attempt it, but I'd probably try and make the front panel into a eurorack panel and change the top jacks. Has anyone successfully made this?
