Portal Point Generator
Back to project overview
An efficient and compact generator that can be coupled with wind turbines or water wheels to produce upwards of 100W
Vijay wrote 04/21/2019 at 14:48 point
I would recommend to go for lower AWG, 18-20, that would reduce the resistive and heating losses as well as reduces the breaking effect when connected to a load. this should allow the turbine to pick up speed, and give you a decent current output, without the need to step down the voltage
MaKoTo wrote 01/19/2019 at 18:23 point
Hi Vijay !
And thank you for sharing and documenting your project ^^
Because the V2 is not finished yet, i plan to realize your generator V1 to test it on my Savonius https://burogu.makotoworkshop.org/index.php?post/2019/01/01/eolienne-axe-vertical-12
I can got easily all the components, but for realisation, but I've two questions :
• To do very precise job on coils, how many turn of the 30 AWG wire have to be done ?
• The enamel copper wire is sell by weight, so, how many weight is necessary to make the 6 coils ?
And bonus question, with time passed and experience acquired, for optimizing the V1, would you still use 30 AWG wire ? In case of not, what AWG of wire  and number of turn do you recommend ?
Good luck for V2 ^^
MaKoTo wrote 07/15/2019 at 13:18 point
Hi Vijay
I finaly realized the generator, and  for my needs, make somes modifications in the 3Ddesign and electrical parts.
Documented here :
https://burogu.makotoworkshop.org/index.php?post/2019/02/22/eolienne-axe-vertical-13
Updated here :
http://burogu.makotoworkshop.org/index.php?post/2019/05/15/eolienne-axe-vertical-15
And Uploaded here :
https://www.thingiverse.com/thing:3675471
Vijay wrote 07/27/2019 at 16:32 point
Brilliant Work! i'm going to post a log about this!
