BlinkyScreen 2.0
Refurbish of my old project https://hackaday.io/project/8723-raspi-wifi-blinky-display
In developement, can change heavily at any time
I made a fancy blinky display using an ancient RasPi 1, because I had one spare back then.
Now I ended up having a spare RasPi 3 B and thought it would be great to refurbish it. And document it properly.
Had an old, undocumented Project. (Kinda try to document it, but thats quite hard after some years).
Also: Got some RasPis 3 for a bargain.
Also: Saw that there's a contest going on.
So i decided to recreate the display...
Blockdiagramm
And how it looks in real live
That buttons in the bottom left is not yet connected. They will be used in a comming update.
Blockdiagramm
JPEG Image - 137.93 kB - 09/29/2018 at 17:55
Preview
OPC.pde
OPC lib by Micah Elizabeth Scott
pde - 11.48 kB - 09/28/2018 at 21:55
Download
fancyFFT_fadecandy.pde
Audio visualization tool
pde - 5.46 kB - 09/28/2018 at 21:55
Download
fcserver.json
Config file for fcserver
JavaScript Object Notation (JSON) - 785.00 bytes - 09/26/2018 at 19:59
Download
  • 1 × Raspberry Pi 3 B
  • 1 × Fadcandy board
  • 8 × 8x8 WS2812 Matrix
  • 1 × Powersupply Beefy enough to deliver enogh power for all the blink
  • 1 × Power Distribution Board Unfortunately i lost the PCB Data, but stripboard should work as well. just power somewhere in the middle
View all 6 components
  • Twitter Visualization
    Tillo10/01/2018 at 06:04 0 comments
    Since Twitter is great for data mining, i hacked together a prototype, also since the weather was great this weekend it's really a hack that needs some (well a lot) of rework, probably need to dive into python multithreading, or reimplent the whole stuff in another programming language, would be a cool project to dive into go once.
    The Idea is to use tweepy's streaming API to filter tweets for up to 512 words stored in a wordlist.
    Then whenever a tweet is written, the coresponding LED gets a bit brighter, until it overruns an start again, so you'll end up with LED blinking faster on often used keywords and slower on less often. (while writing this description: pulsing would be cool too)
    Sorry no video right now, because I really just finished the first code yesterday night, and need to think of 512 keywords first.
  • Obsolete technology
    Tillo09/28/2018 at 22:59 0 comments
    Finally some electronics not used anymore ....
    The yellow PCB is an USB hub, which I used to both power the RasPi and the USB WiFi adaptor.
  • Buildup
    Tillo09/28/2018 at 22:24 0 comments
    Some words on the buildup.
    I lasercuted three sheets of acrylic. Two times in black one in some translucent white. They are held together by distance bolts. My Idea was to screw the LED panels to the middle one and the rest of the electronics to the bottom one... Well, since holes didn't fit, I ended up using hotglue.
    For the panels i took some wood, which was laying around to make some spacers, glued them to the middlepanel and used velcro to mount the LED panels to them.
    For the connection of the panels I used some cables with servoconnectors on both sides and pinheaders on both the leds as well as on the power distribution boards.
  • Audio Visualization
    Tillo09/28/2018 at 05:27 0 comments
    Back in the days I had a Processing sketch which visualized the computer's mic in some different ways:
    • Big dots for frequency analysis.
    • Some waveform of the input ( more in a artistic way)
    • Some agent moving around, speed is controlled by the input volume
    Plus rotation of the whole stuff which can be switched on or off, speed is also depending on the input volume.
    Example (sorry no videgrapher here, just a guy with a smartphone ;) )
View all 4 project logs
  • 1
    Install software on the RasPi
    1. Install Raspian, i just took the standard image.
    2.  Install Fadecandy server  (https://github.com/scanlime/fadecandy).
    git clone https://github.com/scanlime/fadecandy.git
    cd fadecandy/fcserver
    make submodules
    make
    3. Install RaspAp (https://github.com/billz/raspap-webgui),  Tutorial: https://howtoraspberrypi.com/create-a-wi-fi-hotspot-in-less-than-10-minutes-with-pi-raspberry/ the first listing is wrong, instead of
    sudo cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant.conf.sav
    sudo cp /dev/null/etc/wpa_supplicant/wpa_supplicant.conf
     just run the first command
  • 2
    Pluging stuff together (and testing time)
    Connect all your matrixes to the power distribution board and power it up.
    Connect the FadeCandy to the Raspi, throw the fcserver.json into the same directory and start the server using
    fcserver fcserver.json
    in the examples  subfolder of your fadecandy are some examples to test your installation.
    Depending on your layout you need to tweak the config.
  • 3
    Taking care of business (Configure stuff)
    1. Connect to your RaspAp, as described on their github page (see above), configure it to your like.
    2. Setting up the FadeCandy server (taken from awesome as usual tutorial from adafruit  https://learn.adafruit.com/1500-neopixel-led-curtain-with-raspberry-pi-fadecandy/fadecandy-server-setup)
    Copy the fcserver binary and its config to some better place,
    sudo cp fadecandy/server/fcserver /usr/local/bin
    sudo cp fadecandy/server/fcserver.config /usr/local/bin
     To make the fcserver program start automatically when the system boots:
    sudo nano /etc/rc.local
    Just above the final “exit 0” line, copy and paste the following:
    /usr/local/bin/fcserver /usr/local/bin/fcserver.json >/var/log/fcserver.log 2>&1 &
    Reboot your Raspi
View all 4 instructions
