e-ink, BLE enabled 'smart' watch with PCB wristband
I just finished ordering the parts and PCBs for 10 watches. Price breakdown is:
* 25 PCBs for 180$ (+ additional taxes) provided by PCBgogo
* Parts for 10 watches + surplus because of MOQ 350€ provided by Mouser
* additional 5 Displays 36$ provided by Good Display
Material price per watch ~ 60€
Now I wait for delivery. And will build up one sample. If that works well I will build up all ten of them.
After building up all of the ten watches I will be able to supply some of them to people interested. Price point will discussed when it is time to talk about selling. As you can see from the costs a price around 100€ is very reasonable and will mostly cover the cost of this production and previous experiments.
It is time to show the world my progress with this project. I uploaded it to github so you all can have a look and tell me what is wrong with it.
https://github.com/DasBasti/SchmartWatch_Hardware
Next to the KiCad project I also added PDF files of schematic and layout.
Please have a look at it and tell me your opinion before I put 1000$ into ordering a couple.
Here are a few infroations about the design.
The Board outline is designed to be fabricated as a flex PCB. There are a few stiffner areas where there should be a plastic plate supporting the flex board.
The watch is powered by a 3V coin cell that sits in the holder in the middle of the board.
From the cell the 3V are going to the RTC and the writst band brace. If the watch is closed around the wrist it closes the circuit and powers up the DCDC boost converter U2. This generates 3.3V for the whole system.
I ordered a new hardware revision for the Schmartwatch board. This will come with two more features:
Blog article (German): https://www.kurzschluss-blog.de/2018/11/schmartwatch-11-neue-hardware.html
This video shows the display updating a full image
The display can also update a partial area
Great project!
I started on a project similar to this in 2013 (wow, how time files). I put up a presentation for a meetup group I did at the time on Slideshare: https://www.slideshare.net/ErlandLewin/yet-another-smartwatch
I used a Sharp Memory LCD instead of proper E-ink display (but they are quite similar in almost not drawing any current with a static image). I also planned for a small LiPo battery with a USB connector in the watch to charge it. And I had a vibration motor for buzzing (but not audible alarm).
I wanted a touchscreen for interacting with the watch, or three touch sensitive pads below the display, but had issues with the IC I used for capacitive touch detection.
Is it difficult to do the impedance calculations for the nRF BLE antenna circuit with a flex PCB? Are you using a chip antenna or a PCB trace? Is the eInk display flexible? That would be really sweet, but I'm guessing it's not.
I'll be following your project with interest!
Hi, nice project you had goning there. I like the sharp mmeory lcd of my pebble smartwatch a lot. But i wanted to do something with eink.
The BLE antenna is inside the radio module so not on the flex pcb. The PCB has a cutout in the copper pour for this though.
It is possible to add your own program to it using C
Man, I really dig that watchface design! I'd love to have it on my Pebble
Great work on the watch too, it looks amazing
Can you still develop for the pebble? If it is not to hard i might port it there. I still have my pibble time at hand.
I wonder whether you saw this project: https://twitter.com/arturo182/status/1050145301238038528 — it could give you some ideas!
4D Makers
sjm4306
TinLethax
Arnov Sharma
Amazing work! Keep on working!!! :-)
