Teensy Thumb Keyboard
Handheld tactile switch keyboard for Teensy 3.2 compatible boards.
Public Chat
This is a breakout PCB in the shape of a thumb keyboard for the Teensy 3.2. It should also work for similarly shaped boards like such as the Teensy-LC, Butterfly STM32L433 or Dragonfly STM32L476/96.
I wanted a small tactile keyboard with a comfortable layout that could be used in any handheld based project. BASIC game console, graphing calculator, PDA, Raspberry Pi PocketCHIP replacement, etc.
Features
  • Beginner friendly through hole soldering.
  • 60 keys arranged in a familiar qwerty layout with number keys arranged in a numpad.
  • SPI, I2C, and 2 additional GPIOs broken out. Aside from these pins all others are used to read the key matrix.
  • Teensy can be rotated with the micro USB facing up or down. Breakout pins will only work as expected with USB facing up.
I sell on Tindie
PCBs are available on Tindie:
KiCad PCB files, Fusion360 model links, STLs and example Arduino keyboard firmware sketch available at:
Thingiverse entry for the HyperPixel 4 & Raspberry Pi 3 B+ Handheld proof of concept:
Various Keyboard Inspiration Links:
Earlier version of the key faceplate:
View all 14 project logs
nrwest wrote 06/20/2021 at 22:37 point
This is a great project - I love that you have got it working with a Pi Zero and a Hyperpixel screen, this is exactly what I had in mind for another project. Is there anything you would do differently, if you were to design another version? What about backlighting? I'm thinking I'll use these soft-touch switches from Adafruit: https://www.adafruit.com/product/4183 but that's just personal preference.
Thanks again for sharing!
Anthony DiGirolamo wrote 06/21/2021 at 18:53 point
Those soft touch ones look great! They will fit the through hole board for sure which uses 6mm buttons.
Haven't thought much about backlighting. I think you'd need surface mount LEDs to make it work. Probably more spacing between the buttons too. Would be challenging to make a faceplate / case with shine thru key legends.
nrwest wrote 06/21/2021 at 22:26 point
Hm, now that I look further on Digikey, I see that illuminated tactile switches are A Thing. Buying 60 of them would get expensive though! This might be the push I need to make my "goldilocks handheld computer" a clamshell design... that way, with some strategic silkscreen and plating on the PCB, the light bleeding from the  screen might illuminate the keys...
rahmanshaber wrote 07/03/2020 at 07:12 point
What if you use a arduino nano and use i2c to emulate the keys?
will it require you to compile the kernel?
I don't want to do kernel stuff in mu project.
ward wrote 10/10/2019 at 03:03 point
Really great work! I would like to know where is the right button and left button of the mouse?
Chris wrote 03/09/2019 at 02:40 point
Is there a tutorial to put this firmware on teensy?
Vitaly wrote 02/09/2019 at 07:28 point
Awesome, I was looking to design one for a compact Raspberry Pi hand-held computer when I found yours. Just soldered it, working well. Thank you!
fabian wrote 01/11/2019 at 19:06 point
I prefer big keyboard with good keys, look at universal keybooard https://klawiatura.wordpress.com/
Arsenijs wrote 01/08/2019 at 12:41 point
1N4148 are not Zener diodes, do fix - people might and will get confused =)
Anthony DiGirolamo wrote 01/08/2019 at 16:18 point
you're right! Thx for the catch
David Boucher wrote 11/20/2018 at 17:28 point
This looks really good. I've been thinking about something like this for a project I've got in mind but I hadn't come up with a good way to make the key caps. How well do the labels on the keys stand up to use?
Anthony DiGirolamo wrote 11/30/2018 at 03:15 point
No problems so far but I didn't put too much effort into the labels. They are just inkjet printed avery labels. A layer of clear nail polish would probably help preserve them longer.
Mike wrote 11/20/2018 at 00:44 point
This is awesome! Very clean!
I've been trying to do something exactly like this myself, but keep getting snagged. The keyboard has stopped the entire project until I figure it out. I'm inexperienced with PCB design, and haven't been able to come up with something that feels good and stays compact. I'd love to grab one of your spare PCBs, or figure out how to get one printed using the files you provided. I think I already have every part you listed here, except for the side switch.
Cheers!
Anthony DiGirolamo wrote 11/20/2018 at 06:41 point
Thanks! I'll let you know when I have the boards on Tindie. Probably at the end of  Nov / early Dec.
If you can't wait you can upload the kicad_pcb file https://github.com/AnthonyDiGirolamo/teensy-thumb-keyboard/blob/master/hardware/v1.1/teensythumbboard.kicad_pcb
to https://oshpark.com
or the gerber.zip file https://github.com/AnthonyDiGirolamo/teensy-thumb-keyboard/blob/master/hardware/v1.1/plots/gerbers.zip
to another board service like https://jlcpcb.com/quote
The settings I'd recommend for jlcpcb are:
Layers: 2
Thickness: 1.6
Surface finish: LeadFree HASL-RoHs or ENIG-RoHs (don't want lead on a board you may be typing on)
Copper weight: 2oz (1oz is probably fine though, the heavier weight copper stands up better to repeated solder and desoldering I think)
Everything else default settings
Anthony DiGirolamo wrote 12/15/2018 at 00:22 point
Starhawk wrote 11/12/2018 at 05:38 point
'Twould be nice to be able to use this with a Pro Micro or other ATMega32u4-based Arduino board... Teensies are excellent, from what I hear -- but they are also very expensive.
Anthony DiGirolamo wrote 11/12/2018 at 06:50 point
I hear ya there. Main reason for choosing the teensy boards is the amazing USB libraries built in. See: https://www.pjrc.com/teensy/td_keyboard.html your code can have Keyboard.print("Hello!") And the teeny will type that into your computer as a USB keyboard. There is a low cost version https://www.pjrc.com/store/teensylc.html that is pin compatible with the footprint I used. If you don't need USB you can use any microcontroller board and wire the column and row pins directly. They are labeled on the silkscreen. A $1.25 blue pill board would probably work without much effort.
