Arduino nano drop-in replacement with Samd21E18
Samd21 (Arduino zero) based plugin for ARES robot with Arduino nano pinout
Direct drop-in replacement for Arduino nano I am using samd21e18 which live in TQFP32 package, same like on Atmega328 It is much more easy to solder. Optional LEGO compatible border ;-)
Arm Samd21 nano core :)
  • Pinout compatible with arduino nano.
  • Pin nubers are little swaped to make easier board and for compatibility with 328Nano in Ares
  • Almost all pins are populated
  • SamD21E18 for easier soldering
  • some pins missing  A3 A4 are doubled
  • LEGO compatible holes
You can use this board in my other projects
View project log
pt wrote 07/21/2019 at 01:26 point
since it's a samd let us know if ya need any help getting it on circuitpython.org/downloads , feel free to email me ... pt at adafruit dot com
