TelescopeGearingPlate.stlV1 Gearing Plate - Print 2Standard Tesselated Geometry - 67.07 kB - 01/20/2019 at 14:29 |
Pulley100.stl100 Tooth GT2 -2mm pitch PulleyStandard Tesselated Geometry - 1.89 MB - 01/20/2019 at 14:28 |
Pulley25.stl25 Tooth GT2 -2mm pitch PulleyStandard Tesselated Geometry - 520.13 kB - 01/20/2019 at 14:28 |
Pulley20.stl20 Tooth GT2 -2mm pitch PulleyStandard Tesselated Geometry - 416.97 kB - 01/20/2019 at 14:28 |
Pulley100.scad100 Tooth GT2 -2mm pitch Pulley - SCADscad - 18.22 kB - 01/20/2019 at 14:28 |
Pulley20.scad20 Tooth GT2 -2mm pitch Pulley - SCADscad - 18.22 kB - 01/20/2019 at 14:28 |
Pulley25.scad25 Tooth GT2 -2mm pitch Pulley - SCADscad - 18.22 kB - 01/20/2019 at 14:28 |
TubePivotClamp.stlCenter clamp for the pivot point.Standard Tesselated Geometry - 204.57 kB - 01/20/2019 at 13:37 |
TubeSupportRing.stlSupport ring for the paper tube - 3 or 4. For helping to build the tube and support afterwords.Standard Tesselated Geometry - 104.77 kB - 01/20/2019 at 13:34 |
TubeSupportJoin.stlEnd & Joint Support Ring 2 or 3. One for each end and one for the middle joint (if you have one).Standard Tesselated Geometry - 107.31 kB - 01/20/2019 at 13:34 |
image_2018-12-17_00.22.22_6.jpgFirst sample picturesJPEG Image - 334.86 kB - 12/26/2018 at 21:38 |
image_2018-12-17_00.16.46_2.jpgFirst sample picturesJPEG Image - 215.63 kB - 12/26/2018 at 21:38 |
