LoRaSleeve
A wearable that gives Smartphones and PCs access to a campus-wide LoRa Network of similar devices.
A wearable ESP32 based hardware that can connected to a smartphone/PC and allows it to communicate with other device with similar hardware. Communication between the hardware and Smartphone/PC is via BLE. Sub-stations/Routers Could be introduced if needed.
The LoRaSleeve is a small piece of hardware that enables communication between devices connected to similar hardware. The LoRaSleeve is ESP32 based and has a small form factor. This allows for it to be hung around the neck or wrist. It simply connects to the device (PC / Smartphone) through BLE and serves as a portal for sending and receiving messages. Long range simplex communication is achieved with the LoRa RFM95W.
The smartphone or the PC only need to have an application installed. All messaging, encryption, decryption and receiving is done on the device. It is battery powered. The LoRaSleeve could help communication in places where network reception is poor. Underdeveloped communities could benefit from its service.
I will update this as the project progresses.
LoRaSleeve_PCB.rar
The complete LoRaSleeve design files.
RAR Archive - 260.36 kB - 03/18/2019 at 11:44
Download
  • 1 × ESP32-PICO-D4 Microcontroller
  • 1 × LORA RFM96W
  • 1 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × AP2122 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × MCP73831 Power Management ICs / Power Supply Support
View all 6 components
  • Finishing Up and Cleaning Up
    Taiwo16 hours ago 0 comments
    CORRECTION AND CHANGES TO SCHEMATIC.
    It took a while for me to notice a "little" error in the previously posted schematic. I missed a pull up resistor for the buttons and misspelled some net names . Fortunately, I noticed it before starting the layout of the PCB. In my bid to correct the mistake, I thought it wise to review the components used with the device and made the following changes.
    • I removed the OLED in a bid to reduce the power consumed and since all that it display could be inferred by other means (via LED and the PC/smartphone itself).
    • I reduced the number of buttons to two.
    • I added another LED for power and connection indication.
    PCB LAYOUT.
    I began laying out the components on the board with the aim of making the  PCB as small as possible. There was a limit to its size as I used 0805 components for easy hand soldering ( I can't cope with smaller components ,YET ). I used the ESP32 Pico D4 chip for smaller size. The PCB measured 5 cm by 3.6 cm at the end.
    The new schematic and layout has been uploaded in the project page. Off to JLCPCB...
  • Let's Begin
    Taiwo4 days ago 0 comments
    SO FAR...
    When I created this project page, I had no LoRa module at hand . I still don't, but I had to get started. I checked my stash of unused components, and found a pair of NRF24L01.
    An RF transceiver, that is not LoRa.
     I played around with its transmission and reception of  messages. I used Serial via the Android Arduino application serial console on both phones. It worked, not well enough, but enough to prove a point.
    My Android development skill is close to non-existent, and I hope to use Thunkable to make an app that interfaces with the ESP32 Bluetooth and sends and receive message from the hardware.
    PCB DESIGN
    I began making the schematic diagram early this morning. The device was to have
    • A small screen to display basic information like battery level, number of connections  etc.
    • A rechargeable battery
    I  used 0805 components and the ESP32 Pico D4. The PCB layout is not complete and I thought I'd share the PDF of the schematic.
    This is the progress so far.
View all 2 project logs
Taiwo wrote 03/07/2019 at 05:26 point
Thanks a lot.
Josh Lloyd wrote 03/06/2019 at 18:24 point
This is a very cool idea. One thing I personally think will be important is end-to-end encryption between devices. Especially if the relays are open source
Taiwo wrote 03/06/2019 at 19:38 point
Yes, that's a good one.  I might have to learn a thing or two to implement that though.
Josh Lloyd wrote 03/06/2019 at 21:22 point
When you eventually get there I'd be more than happy to help.
