Universal LiPo/Li-ion UVLO (undervoltage lockout)
Feature-packed over-discharge protection. Set the cell-count (2S to 7S), minimum cell voltage and dip-time below threshold. Fully hackable!
JanJan
This board will solve one problem in my (any maybe your!) workshop and projects:
Using whatever battery you want for your projects without it being deeply discharged and damaged! The system automatically disconnects your load when the battery drops below the set voltage per cell for the set period of time.
ONE board for all your needs from 8.4V to 29.4V (2 ... 7 cells). The real beauty is in the users freedom of choice. You:
- want to discharge your cells to 2.8V or better just to 3.2V to be safe? Go for it.
- expect heavy load-spikes near the cutoff-voltage which would set off any usual load-disconnect early? Set the dip-time to 5s, so your batteries can recover from the heavy load without the system turning off!
A reset from the trip-point can only be done manually by the user.
Short summary
Use this board for all your battery powered projects, especially those using lithium ion or lithium polymer cells. It cuts the load from the battery if the user-set parameters are met and prevents the cells from deep-discharge, which can and will destroy the battery in the long run.
Key features
  • Works from 2 to 7 cells.
    • Battery-voltages vary depending on charge:
      • 5.4 … 18.9V @ 2.7V/cell (max. allowed repeated discharge)
      • 7.2 … 25.2V @ 3.6V/cell (nominal voltage)
      • 8.4 … 29.4V @ 4.2V/cell (fully charged)
  • cuts off load when the battery voltage
    • sags below a user set threshold
    • for a user-set duration
  • no automatic reset, user manually re-enables the device
  • super low Rds_on N-Channel MOSFET for output switching
  • supply current (ON, working): 1mA
  • quiescent current (OFF): < 1µA
Basic mode of operation
With three potentiometers you set the cell-count, the cut-off voltage per cell and the time the voltage needs to be below the threshold to cut the load from the battery.
The battery is connected with an standard XT60 connector, which is common for Li-Ion and Li-Po batteries. The load is connected on the opposite side of the board with screw terminals. It is initially off.
The board is activated by a short press of a button and the load is switched on if the battery voltage is high enough.
  • 10 – next iteration
    Jan19 hours ago 0 comments
    Where to go from here
    So, I did a few tests with DC/DC buck regulators and "standard" LDO linear regulators. DC/DC has been very easy with the right board layout, ripple is not too much of a problem...
    But there's two drawbacks which pushed me in the linear regulator direction again:
    • higher current consumption in low current draw scenarios (major drawback)
    • more expensive, more parts (minor drawback)
    What is my solution?
    I will use the cheap and durable (in my limited test samples at least) Nanjing Micro One Elec ME6203 regulator. It is a china brand, which means there's no chance getting it from Digikey or other major vendors, but this is a minor concern for me at this point. I just want my hand full of working boards :)
    I will add an 5V6 zener diode at the output to clamp the 5V rail to a 6V maximum (which is including the zeners tolerances). The ME6203 shorts out at 20mA, heats up and survives this condition for hours.
    My overall power requirement will be well under 5mA. The Attiny will be clocked at 1Mhz internal RC oscillator which is plenty for burst-reading 10 ADC values at 10Hz. Conversion time for the first reading is around 25µs and 13µs for the next reading.
    A very interesting approach would be the Attiny1616: it has the internal capability to to burst-readings (up to 64) and give the average from that... See here for details!
    When will the next set of boards be ready?
    Soonish :)
  • 09 – first DC/DC tests
    Jan07/04/2019 at 19:31 0 comments
    Update – 2019-07-15
    The ripple-measurement screenshots I originally posted below were done with the ground-wire-alligator-clip-method and not the correct direct-connection method. See this Application note by Analog [p.5] for more details how to do it correctly. Analog doesn't call it "Incorrect Ground Loop Method" for no reason...
    Measuring this way (and setting the probe to 1x = no amplification) the ripple reduces to the more reasonable 30mVpp I mentioned in my updated log below.
    Update – 2019-07-10
    Using the DC/DC buck converter with nearly 30mVpp ripple the ADC readings by my Attiny861A test board are always within 0.05V of "jitter" between readings (each reading is an average of 10 single readings).
    So, the circuit seems to work just fine. Problematic thing is the "no load"-current of nearly 0.55mA which is too much drain on my projects batteries for my taste.
    We'll see where it goes from here...
  • 08 – thoughts about linear regulators
    Jan06/28/2019 at 07:15 4 comments
    There are some laws that just can't be bent. Ohms law is one of those. It dictates the law of conservation of power, which means: P_in = P_out.
    So, you can't just expect the small linear regulator in a SOT23-5 case to convert 40V to 5V and 100mA without getting hot.
    The power dissipated by the regulator will be:
    The biggest "drivers" here are the input voltage and the current at the output. I need at least 10mA to guarantee safe operation while switching the MOSFET. The ground current usually is in the range of 100µA.
    With a full 8S (yes, I want to extend to this cell-count) battery at 33.6V this means around 0.3W of power which the regulator needs to get rid off.
    SOT-23 cases feature very bad thermal design with around 170°C heat-up per W dissipated power. That's the "Junction to ambient thermal resistance" value in the datasheet. The value is so high because the plastic case has no metallic pad which could transfer the heat into the PCB much more efficiently.
    So, 0.3W x 170°C = 51°C heat on top of the ambient temperature. This would be okay on paper but it creates a hot-spot on the PCB which spreads to other parts which have a drift with temperature...
    The paper linked above has good design techniques for this style of case. I'll definitely try that anyway as the DC/DC chips I want to try are in that case too. Richtek has some good info on this as well.
  • 07 – new linear regulator tests
    Jan06/26/2019 at 19:30 5 comments
    Update 2019-07-15
    I tested two of the regulators. Both work quite well and didn't release the magic smoke yet. Even after the the repeated inrush-current tests (repeatedly connecting the fully charged 6S lipo battery) with the load connected.
    The MD7350H does indeed use the full 3% output voltage tolerance stated in the datasheet and is my least favorite part.
    The much smaller ME6203 works perfectly up to 38V and limits itself when short-circuited. It puts out perfect 5.00V under up to 20mA load and has a smaller footprint than the MD7350H. Using bigger PCB traces on all three pins will wick away enough heat to ensure proper cooling at 5V/10mA out (max).
    At 2.7µA current consumption with no load (µC in power down state) it's well within what I need for low battery discharge when the circuit cuts the connection. I think my next set of PCBs will use this regulator!
    The SY6345's are still in their anti-static bag and will be tested next.
  • 06 – new DC/DC buck design
    Jan06/25/2019 at 20:41 0 comments
    After all but the last regulator blew, I wanted to test a DC/DC power supply next. So I quickly made a little board around the Rohm BD9G102G-LB DC/DC buck regulator which is quite close to the reference design from the datasheet.
    Aisler online rendering
    KiCad rendering - parts included
    The boards are 25x20mm in size. I use a bigger inductor than is probably needed for 20mA max output, but I wanted to try a few different ones and look at the output waveform on my scope. Rally can't tell how the ripple will affect the ADC readings of the chip. We will see how that works out. Found a nice paper on reducing ripple by TI...
    I'd love to use a small 1206 chip inductor to keep everything nice and small! Resistors and caps will be 0603 instead of 0805 too for the final board.
    I ordered three copies of the board together with all the parts for 18.30€ from Aisler in Germany, so I expect them to arrive in 7 or 8 days as they usually do. The parts are sometimes a bit more expensive when ordered through Aisler, but you don't have to come up with other stuff to get to 50€ free shipping at Digikey, so that's fine I guess...
    Hope this design works :)
  • 05 – project is not dead yet
    Jan06/21/2019 at 09:03 7 comments
    So, after having so much trouble with the failing regulator I finally found the culprit: the regulator needs at least 4.7uF of ceramic capacitance at its INPUT to keep it from blowing up.
    This does generate another problem which is arcing when connecting a battery, caused by the near short circuit behavior of an discharged cap...
    So to keep things short I found a few other regulators that I want to try:
    I'll decide for one and come back to you with a fresh design.
  • 04 – unpredictable? regulator fails :( HELP!
    Jan06/17/2019 at 19:12 0 comments
    Aaaaaaaaaah!
    After I did the first tests with the first board (and writing my very happy post about it) the next day I connected the board to a fully charged 6S LiPo battery again and got... the magic smoke.
    the circuit in question
    After inspection of the board it was obvious that the regulator blew. I double checked all the parts in the schematic, found no obvious error and re-worked the regulator and Atmega328. It worked a few times after that.
    A few days later I even did rests with the same LiPo and a 150W electronic load to test the MOSFET for heat dissipation. Worked like a charm.
    Then on some random re-connection of the battery blew the regulator (and micro) again. DOH!
    Tests I did
    So, I did solder just the TPS70950DBVR on an breakout board, added the caps needed (50V rated, low ESR MLCC) and did some tests again.
    Leaving EN floating (according to the datasheet) and with no load connected, the regulator seems to be super sensitive to repeated quick connection of 30V with a high current capability (DSP5005 srt to 30V/5A).
    It seems like the inrush-current can kill the regulator?! At least that's what happened a few times. I'm through 6 of my 10 regulators now...
    Did the same tests with an 100 ohm load resistor to simulate 50mA output current and saw some heavy heat-up of the regulator with a over-temp shutdown by the regulator. With 20mA output it got quite hot but didn't shut down.
    Connecting the 30V current-limited to like 100mA seems to reduce the chance of the regulator popping.
    Conclusion
    I really can't reproduce the error reliably... The inrush-current theory is just that, a theory. I tried several other things which I thought could be the reason for failing, like: too high enable voltage, wrong caps, other style of caps, wiring, ...
    To sum things up: the boards are NOT going to production any time soon. Did check several other regulator options but can't seem to find any good one yet.
  • 02 – v0.2 boards fully functional!
    Jan05/16/2019 at 20:17 1 comment
    In my last log I mentioned just a few quick things. Now it's time to tell you the following:
    My v0.2 boards are fully functional without any modification. Can't remember when this happened the last time, if ever :)
    A few notes:
    • current consumption when active in the single digit mA range
    • current consumption when OFF: 0.45µA
    • wake-up from OFF-mode only by pushing a button connected to the board
    • pushing reset == OFF
    I wrote a quick first-try program for the boards which I will refine a bit next week and upload.
    When this is done, you could order those boards, solder them and add them between your valuable rechargeable batteries and your devices.
    I'll put up all the needed files shortly!
  • 03 – cutting costs
    Jan05/01/2019 at 10:20 1 comment
    What is the aim?
    This log is all about: How can we make the whole board cheaper while keeping all the features and not killing its safety functions. This all refers to the early v0.2 version which is by no means optimized yet!
    Ways to cut costs
    I try to think of mass production here (Disclaimer: I AM NO PROFESSIONAL, it's just what I would do to keep it cheap).
    Let's say we want to make a thousand of those boards to sell them. A few thoughts come to my mind then:
    1. less parts = cheaper
    2. substituting expensive parts with widely available "china brands" = saving costs
    3. using jellybean parts and same footprints
    4. smaller boards = cheaper
    5. boards need to come fully assembled
    6. [...]
    Let's get into more details here
    The above points will be anatomized in greater detail here.
    1 – using less parts
    This is a no-brainer, right? It's not as easy as it sounds. Most parts are there for a reason, so we need to look at every part and ask ourselves: do we really need it?
    Here are a few parts which can be substituted by other brands but can not be left out altogether:
    • Microcontroller: needs to be there for all the main functions and hackability
    • MOSFET: our main-switch
    • input and output connectors
    • a voltage regulator: we need at least a low-Iq 5V rail for our logic-level MOSFET
    • a few caps at the various inputs of the chips for stability
    So, if all those parts are needed, which parts could we possibly cut from the list? A decision in this category usually has some effects on other parts of the circuit.
    1.1 - choosing another voltage regulator
    The TPS70950 is a nice LDO voltage regulator with an EN-pin and <0.1µA quiescent current in shutdown mode. Neat! But this comes at a cost: €0.3395 per piece buying 1000.
    No we need to ask: what OFF-current draw can we accept? From other circuits I know we can get ATMEGAs and ATTINYs down to around 2µA total using a system load switch. Say, we would accept 10µA total OFF-current. This doesn't drain an already "empty" cell too much. So we have 8µA for other parts. A hint from @Simon Merrett was using an HT7550-1 from Holtek. These draw max. 3µA idling (with no load), having no EN-pin though.
    Fits our bill perfectly! Costs €0.075/pc buying 1000. Here's what I mean with changes down the line when substituting components:
    voltage regulator in v0.1
    Looking at the circuit above we can use the HT7550-1 instead:
    The 1µF caps can stay in place, no need for 10µF in our circuit, cause it uses only little current.
    Changes to the circuit are:
    • the EN-button needs to be tied to one of the µC's interrupt pins
    • ZD1 can be left out as the 5V rail will be always on. While not exactly expensive it's another saving!
    • R3 can be omitted as well
    Total savings: Around 87%. or 265€ per 1000 boards.
    1.2 - choosing another MOSFET
    With MOSFETs it's a bit more like "pay less get less". Considerations are:
    • Switchable current 8A (10A) max.
    • max. input voltage 30V
    • no mounted heatsink
    • small PCB area
    So, we need a type with a maximum drain to source voltage of > 30V to keep the MOSFET from destruction, that's why I chose 40V (the v0.1 one has 30V max.).
    Next consideration is the resistance RDSon at a gate voltage of 4.5V. Datasheet values are mostly for a MOSFET silicon temperature of 25°C. So we need to de-rate it with the given value of the datasheet to be sure it is proper low resistance even when hot.
    With little board-space we need to take the heat-up into account which is around 50°C per W of "wasted" current.
    A quick look at Digikey presented me the SiSA72DN.
    On-resistance is around 0.007 ohm at a die-temperature of 125°C and 4.5V gate-voltage.
    Fits our needs perfectly and has a very small footprint...
  • 01 – boards v0.2 ordered for tests
    Jan04/27/2019 at 11:20 10 comments
    Update May 15th, 2019
    Just soldered the first V0.2 board on a hot steel plate:
    It works, burned the bootloader (for fuses) and the blink sketch. Runs just fine. Next I'll try to read the three pots and switching the MOSFET on/off.
    Edit: Everything seems to work so far. Will post an update soon to keep you posted!
View all 10 project logs
Simon Merrett wrote 04/28/2019 at 10:38 point
Hey @Jan I know this is a preliminary version but is there a schematic you are happy to share?
What regulators are you using?
Also, what MOSFET do you envisage using and at what price? Maybe we can find something with equivalent RdsOn and logic level driving?
What about a "Pro" version which adds JST balance connectors and has the ability to monitor each cell individually?
Ref the pots, what about fixed resistors and pin header bridge jumpers? Just move the bridge jumper across the correct pair of pins for your configuration. Not as compact as pots but doesn't require a screw driver / flat tip to switch. Dip switch would be the same but I don't think it's cheaper than the pots.
To shrink the board, can you put the FET and connectors on the bottom?
For the microcontroller, how about the new ATtiny range (404, 814 etc)? Given the low speed requirements for the processing, they have some fantastically low current options when running on their internal 32kHz oscillator.
Jan wrote 04/30/2019 at 16:55 point
Hi @Simon Merrett
Let me address everything individually:
1) schematics are in the files section
2) the regulator is a TPS70950 which works up to max. 30V input
3) you're right with the MOSFET. I changed it to an ultra low Rds_on one (1.1mΩ @ 4.5V gate) so I can ditch the driver
4) a pro version is not planned yet. I have to take sume things as granted, which in this case includes propperly balanced/charged battery packs
5) I used pots because the user can set the setting quickly and individually without the need to fling a soldering iron or something.
6) all alternatives to tiny pots seem to use more board space :(
7) board shrinking will be done in the next iteration!
8) the micro will be changed to some easy to program Attiny.
I appreciate your very eye-opening and competent help so far!
