digigurdy@gmail.com Video clips of it being played & overview of new DigiNerdy:
DigiGurdy Users Group: https://www.facebook.com/groups/2385106478458532
11/1/21 In addition to original 14 basic tuning options I have an alternative tuning method code (see Files) that instead gives you just 4 basic tunings BUT you can shift all strings up/down 1 octave and it has a Capo function too.
28/02/2021 : New design in collaboration with Jaap Brand of NerdyGurdy fame. Undocks into 2 parts; a fully playable keybox and a main body with crank simulator.
What is it?
In addition to the above, a hurdy-gurdy also has drone strings and a buzzing rhythm section operated by varying the rotation speed of the crank handle. It has been described as the stringed equivalent of the bagpipes and, as with bagpipes, there are design variations in the folk traditions of different countries. Links to videos of real hurdy gurdy players are provided.
The Digi-Gurdy is an electronic hurdy-gurdy keybox, with correctly placed keys, that outputs MIDI (an industry standard digital communication system for electronic musical instruments) via a USB cable to an attached laptop or phone running suitable MIDI player software. When used with headphones this would give you a low cost, portable, compact and silent means of playing the equivalent of the melody strings, i.e. something to learn to play on wherever you may be. It would not even require a battery as it would be powered via the USB cable.
Are you building any?
The plans I have uploaded can be used with a hand wired loom. I also have a custom PCB onto which all switches and Teensy can be mounted PLUS the Teensy microcontroller is then un-pluggable, so non-Arduino enthusiasts could just mail me the Teensy for a code upgrade. A bit left-field but solves a real world problem!
Why?
1) Major barriers to entry for beginners are that while a playable electric guitar for example can be bought for around $200, a hurdy-gurdy is made to order by a specialist luthier and costs around $1500 even for a basic instrument with a waiting time of several months to a year.
2) In addition, it is noisy, making a good place to practice without upsetting your companions hard to find! This problem has been solved for bagpipe players with the availability of both practice chanters resembling a simple flute and electronic e-chanters allowing practice while wearing headphones.
How it works: The entire structure of my first attempt was 3D printed in ABS plastic. The keys press on micro-switches and the brain of the device is an Arduino Teensy 3.5 microcontroller. An OLED display shows you which note you are playing at any time. The new one documented here uses alloy extrusions to create a better quality device, with 3D printed components and white laser cut front and back acrylic panels.
It also has a Demonstration Mode which plays a selection of >20 songs at the speed of your choosing while displaying the notes on the OLED screen. NOTE: Some of these need more work, feel free to edit them! I have simulated the crank using a hobby robot gearmotor as a dynamo.
Primary objective: To produce the Digi-Gurdy design which could be assembled by someone around 14 years or older with basic soldering and model making skills.
NOTE: Click on my name and send me a private message to obtain the soundfont file for use on the attached mobile phone as it seems to be too large for me to upload anywhere.
Video examples of various styles of hurdy-gurdy players, in no particular order:
Jiří Wehle, Prague street performer
Example of a younger player, Patty Gurdy.
Video about the Black Sails TV series soundtrack
Jimmy Page playing HG in the film: The Song Remains The Same
Hi John, I'm currently building one. Used parts of https://www.thingiverse.com/thing:4305281 which I've modified in a way that I couldhave printedthem on my 3D printer. Idea is now to cover up all with some nice wooden verneer which I have from previeous projects and add some metal weight (printed parts are a bit too light). What I'm missing are the soundfiles for FluidSynth. How can I get them ? Thanks and take care.
