The Digi-Gurdy
MIDI based electronic portable practice hurdy-gurdy.
The hurdy-gurdy is an ancient musical instrument (10th century) with drones and melody strings bowed by a rotating wheel, played by pressing keys which contact them at different points. It has in more recent times featured in the TV series “Black Sails”, “Walking Dead” and also in the “God of War” games.
The major barrier for beginners is that they are very expensive and built to order with lead times of several months to a year. Rather like bagpipes, they are noisy when practicing. For pipers, practice chanters and e-chanters are available to solve this problem while nothing similar is available for the hurdy-gurdy.
The Digi-Gurdy therefore is an electronic hurdy-gurdy keybox, with correctly placed keys, that outputs MIDI via a USB cable to an attached laptop or phone running suitable MIDI player software, for practice anywhere using headphones.
What is it?
In addition to the above, a hurdy-gurdy also has drone strings and a buzzing rhythm section operated by varying the rotation speed of the crank handle. It has been described as the stringed equivalent of the bagpipes and, as with bagpipes, there are design variations in the folk traditions of different countries. Links to videos of real hurdy gurdy players are provided lower down this page.
The Digi-Gurdy is an electronic hurdy-gurdy keybox, with correctly placed keys, that outputs MIDI (an industry standard digital communication system for electronic musical instruments) via a USB cable to an attached laptop or phone running suitable MIDI player software. When used with headphones this would give you a low cost, portable, compact and silent means of playing the equivalent of the melody strings, i.e. something to learn to play on wherever you may be. It would not even require a battery as it would be powered via the USB cable.
Why?
1) Major barriers to entry for beginners are that while a playable electric guitar for example can be bought for around $200, a hurdy-gurdy is made to order by one of a few specialists and costs around $1500 even for a basic instrument with a waiting time of several months to a year.
2) In addition, it is noisy, making a good place to practice without upsetting your companions hard to find! This problem has been solved for bagpipe players with the availability of both practice chanters resembling a simple flute and electronic e-chanters allowing practice while wearing headphones.
3) Even if you do order one, you need something to learn to play in the meantime, while you are waiting for it to be built.
How it works:
The entire structure of my first attempt is 3D printed in ABS plastic. The keys press on micro-switches and the brain of the device is an Arduino Teensy 3.6 microcontroller. An OLED display shows you which note you are playing at any time.
I also envisage a Demonstration Mode which would play a selection of songs at the speed of your choosing while displaying the notes on the OLED screen as it goes.
At present it has a fold up handle held in the right hand which helps stabilize it while the melody is being played with the left hand. In the real instrument the right hand would turn a crank handle, which is a separate skill to be learned in its own right and I am investigating ways to simulate this action that remain compatible with the overall concept of a compact portable instrument.
Primary objective:
The ultimate aim of this is to produce a version 2 of the Digi-Gurdy either fully built or as a kit which could be assembled by someone around 14 years or older with basic soldering skills and the ability to complete a plastic model kit.
Version 1 is entirely 3D printed in bright red ABS blocks which are glued together, with a flip up OLED screen and a folding handle for the right hand which originally was an accessory for stabilizing an SLR camera. The files are attached below along with an assembly and use manual.
The next version needs to
i) Have a reduced number of printed parts and be easier to assemble.
ii) Be more robust.
iii) Have the option at least of adding in a simulated crank handle module.
Video examples of various styles of hurdy-gurdy players, in no particular order:
Nigel Eaton
Nigel Eaton with Led Zeppelin
Gregory Jolivet
Harry Wass
Efren Lopez
Tobie Miller
Andrey Vinogradov
Mr Wehle, Prague street performer
Example of a younger player, Patty Gurdy.
Video about the Black Sails TV series soundtrack
BuildManual V1.5.pdf
Build Manual for Version 1, including how to connect it to a laptop or phone to generate the sound.
Adobe Portable Document Format - 3.59 MB - 05/09/2019 at 09:17
Preview
Download
DigiGurdy_electronic_hurdy-gurdy_keybox.zip
All files including .stl files for Version 1
x-zip-compressed - 6.86 MB - 05/09/2019 at 09:16
Download
  • Log #6: Fully Assembled With Crank Module
    XenonJohn3 days ago 0 comments
    Here is the DigiGurdy coming together at last, with the crank simulator module attached. This video clip gives an overview of the functions of the device from the point of view of a user and also shows how you select and play songs in demonstration mode. I will add a more detailed video at some point showing you how to get the soundfont onto your phone and set it up to play the sounds correctly with the current version of the DigiGurdy. In this update video you can see:
    - Crank operated drones and open melody string.
    - Crank operated buzzing sound (sound audio file supplied by Nigel Eaton, many thanks).
    - More realistic key-click sounds
    when the keys are pressed.
    - Use of a control knob to adjust the sensitivity of this buzzing rhythm sound when cranking to suit your own style of playing.
    - Blue orb on front panel which glows when turning the crank.
    - Demonstration of the crank-override switch which allows you to practice the melody without need to turn the crank.
    - Demonstration mode is shown being used with user-selection of songs and playback speed.
    The whole assembly is held together with just 4 long screws at each end. Almost no adhesives are required apart from where the screen is held in position.
  • Log #5. Workable crank solution found at last
    XenonJohn08/06/2019 at 12:00 0 comments
    Project Log #5. DigiGurdy project.
    I finally have a reasonable crank simulator now i.e. a robot gearmotor in reverse (where the crank spins up a motor acting as a dynamo). To create resistance to turning I originally shorted out the motor connections which long term is probably a bad idea as it can cause arcing at the motor brushes and so on.
    Here, to create a more controlled load on my dynamo, I experimented with secondary motor + wind resistance vane, inspired by old clock chime mechanisms, before settling on a simple filament torch bulb (remember those?) as the best low cost compact solution.
    To be clear, I could have a large pulley with an adjustable friction band around it, or a wheel with a friction material against its edge. That would cost more, be less compact and also push the assembly and adjustment/fettling time up to get it all working properly. The gearmotor-bulb is low cost, compact and just bolts/glues in place. Also as the bulb flashes nicely with each burst of crank rotation speed which in a hurdygurdy also creates the buzzing rhythm sound, I may be able to make a feature of it.
    I am retaining the chopper wheel which senses the speed of rotation of the crank. Originally I had thought I might measure the voltage output of the motor using one of the Arduino analog input pins. However the chopper wheel does have low latency, is working well and the sensor adds almost no extra cost.
    Most of the cost of a real hurdy gurdy is the labour of the skilled luthier who builds it. Part of this project is to keep the human assembly time down to an acceptable level to make this an affordable compact second instrument for silent practice. This is why, if I can use or adapt a more or less pre-assembled mechanical mechanism, I will do so where possible.
  • Crank handle chopper-wheel experiments and progress
    XenonJohn07/28/2019 at 19:48 0 comments
    I have been experimenting for quite a while now with robot gearmotors as a means of creating something that can be hand cranked, with just the right amount of resistance to turning. I have been encouraged by Nigel Eaton (Hurdy Gurdy maestro) to continue my effort to simulate a crank handle if at all possible and not give up on this aspect of the project. Again, where possible I am trying to keep the component costs down.
    The Teensy microcontroller inside the DigiGurdy needs information on the rate of rotation of the crank. When the crank is turning, the Teensy can then activate the simulated drone strings and open melody string(s) to simulate what would happen when the rosined wheel rubs against or bows these strings in a real hurdygurdy. Furthermore, whenever the rotation suddenly speeds up, it can then also simulate the buzzing sound that this would normally produce, i.e. the rhythm part of a hurdygurdy.
    I have created a 3D printed chopper wheel which intermittently breaks the infra-red beam of a low cost sensor designed for this purpose. This structure has an unusual shape as it has to be somewhat removed from the area where your hand is cranking the handle to avoid damage, it also has to be shaped to fit onto the shaft of the fishing reel crank I am using, while also allowing access to the grub screws that hold the handle onto the motor and also fit over the end of the motor.
    I used software with interrupts for reading position encoders etc. but had major problems as the program would freeze and crash when connected to the phone but not when using the Serial window of my laptop. I eventually found a frequency counter library designed for the Teensy microcontroller and this works really well.
    I now have all the functions above more or less working OK, i.e. the drones come on when you turn the handle, the trompette buzz sounds when you accelerate your rate of turning and you are able to play the melody on the keys once the handle is turning. I am very pleased with the outcome so far.
    The next step is to redesign the enclosure for this so it is more in keeping with the rest of the DigiGurdy so can be added to the end in a modular manner.
  • Experiments to simulate a crank handle
    XenonJohn07/08/2019 at 11:09 0 comments
    Having finally worked out how to play the buzzing rhythm sound from the soundfont file on the attached mobile phone MIDI player, at present by pressing a button on the handle, this means I can now replace this button in theory at least with some form of crank handle.
    The crank handle is low cost and intended for a fishing reel. I have attached it to a motor which has a reduction gearbox. I had to buy 3 motors with different reduction ratios before I found one with the right amount of mechanical resistance to turning. In this video update I show each motor and also show how I can make an attached pager motor buzz by turning the crank. As the handle on the current Digi-gurdy can slide fully out and is attached electronically to the main body via a headphone plug, this means it could possibly be replaced by a crank module with no modification of the main body of the device, for those who wish to try it. More work required here but clearly this has potential. I will see how I get on and show the results in the next update.
  • Setting up Digi-gurdy with drones & rhythm buzz via a mobile phone
    XenonJohn07/08/2019 at 11:00 0 comments
    Update 08/07/2019
    Setting up the Digi-Gurdy to play via a mobile phone.
    I have now worked out how to play the melody via Channel 1 of a MIDI player running on a phone, the High D trompette via Channel 2, a Low G drone via Channel 3 and the crank-activated buzzing rhythm sound via Channel 4.
    The MIDI player is free and called FluidSynth. The soundfont file (a library of sound effectively) that it uses is from the open source MIDI-gurdy project https://github.com/midigurdy/midigurdy to which I have added an extra buzzing sound.
    By pressing the upper green button on the handle, the device behaves as if you are turning the crank handle, i.e. you get the drone sounds you have set up plus the open melody string (G4). You then play the melody via the keys while the drones continue to sound.
    In this version, the lower yellow button on the handle activates the buzzing trompette sound which is the rhythm section of a hurdygurdy, normally produced by momentary increases in rotation speed of the crank handle.
    This means, in my next update, I can look at ways to simulate the crank handle by generation of a suitable voltage signal to the Arduino Teensy via a geared motor to which a crank handle has been attached.
    I have also included in the video two quick bursts of the device running in demonstration mode just for fun.
  • Hurdy gurdy basics & Digi-Gurdy physical design.
    XenonJohn05/24/2019 at 15:05 0 comments
    Here is a video outlining the main features of a hurdy gurdy, the instrument we are aiming to partially emulate with an electronic practice version.
    The Digi-Gurdy presents two challenges. The first is the physical design and the second will be the internal electronics. It must be compact, have keys with the same layout as a real hurdy gurdy and while looking good, must be potentially capable of manufacture at reasonable cost. Current experiments combine 3D printed parts which could ultimately be made of plastic in combination with a frame which includes aluminium extrusions.
    - There are ongoing experiments in an attempt to simulate a crank handle but for now a rigid handle is provided for the right hand, which helps you stabilize the device on your lap while playing the keys with your left hand. This may end up being the best compromise.
    - This handle is a commercially available plastic pistol-grip handle for cameras.
    - It has been fitted to an alloy bar which slides telescopically out of the body of the Digi-Gurdy.
    - This keeps the device compact and portable.
    - The OLED screen has been relocated into the main body of the device to improve ruggedness.
    - The keys are no longer held in place by a small bolt through their tail ends but now reversibly snap into place. This will reduce assembly time and allow easy replacement if ever damaged.
    - The micro switches for each key also now push-fit into their sockets without requiring glue to hold them in place. I am now also using roller switches as they give a great feel to the key action.
    - I could use resistance wire, contacted by the keys, or a ribbon potentiometer. This would reduce the quantity of wiring, however microswitches will probably be more reliable after heavy use, are designed to operate many thousands of times, give a good feel on each keypress and also return the keys well to their start positions after being pressed.
    The video below outlines the main aspects of the physical design. The electronics will be the subject of future updates.
    Here are the main parts laid out on the bench.
View all 6 project logs
XenonJohn wrote 07/21/2019 at 17:10 point
Bear in mind that there is a learning curve with 3D printers and it is worth printing a few things that do not matter to you very much just so you become familiar with your particular machine. One or two of the very low cost ones out there are now pretty good.
Jack Walsh wrote 07/21/2019 at 16:01 point
I was just putting together the main body of my digi-gurdy and noticed that there are apparently new print files for redesigned parts.  When will these be released?  I'm willing to start over!!  I particularly like the new key design -- the screws through the keys always seemed unworthy.  Thanks for all your work!!!!!
XenonJohn wrote 07/21/2019 at 17:08 point
If you can wait a few weeks I will soon have a lot more free time to really finish this off. On expert advice (Nigel Eaton) I have been encouraged to really try to get a working crank handle simulator completed as part of this project. This will mean the 3D files might change yet again. Crank work will be feature of next update, more parts on order right now.
Jack Walsh wrote 07/22/2019 at 14:38 point
Yay!!  Gives me some time to practice with just the keys!!!
Shannon wrote 07/05/2019 at 17:53 point
This project might well be the one that makes me buy a 3D printer. I'd still save money over buying an acoustic hurdy gurdy.
