Standard Tesselated Geometry - 49.20 kB - 08/19/2019 at 22:18 |
Standard Tesselated Geometry - 52.04 kB - 08/19/2019 at 22:17 |
Standard Tesselated Geometry - 96.27 kB - 08/19/2019 at 22:16 |
Spacer 0.5mm.stlIt prevents contact between stators and rotors.Standard Tesselated Geometry - 70.20 kB - 08/19/2019 at 22:14 |
Standard Tesselated Geometry - 400.38 kB - 08/19/2019 at 22:13 |
Standard Tesselated Geometry - 482.60 kB - 08/19/2019 at 22:12 |
Standard Tesselated Geometry - 539.34 kB - 08/19/2019 at 22:02 |
Standard Tesselated Geometry - 538.56 kB - 08/19/2019 at 22:01 |
Standard Tesselated Geometry - 538.95 kB - 08/19/2019 at 21:59 |
Body Case Cover.stlAside from as a cover, it holds the case and shaft stationary.Standard Tesselated Geometry - 287.48 kB - 08/19/2019 at 21:52 |
Counter to Rotor 1.stlIt houses the Brake Bar and makes the torsion spring engaged in a counter-clockwise direction.Standard Tesselated Geometry - 964.83 kB - 08/19/2019 at 21:19 |
Bushing.stlIt holds the Rotor 1 in place and acts as a stopper so that Rotor 1 and "Counter to Rotor 1" will rotate counter-clockwise together.Standard Tesselated Geometry - 202.33 kB - 08/19/2019 at 21:03 |
Lock.stlIt holds all major components in place.Standard Tesselated Geometry - 2.46 MB - 08/19/2019 at 21:01 |
Cover to Rotor 1.stlIt serves as cover to Rotor 1 and holds the "Counter to Rotor 1" in place.Standard Tesselated Geometry - 132.21 kB - 08/19/2019 at 20:57 |
Body Case.stlIt serves as a housing for electronic components and as a handle for the user when cranking.Standard Tesselated Geometry - 1.14 MB - 08/19/2019 at 20:55 |
Fastener and Cover to Rotors & Stators.stlThis holds the Rotor 1, Rotor 2 and Rotor 3 altogether.Standard Tesselated Geometry - 219.71 kB - 08/19/2019 at 20:52 |
Stator 2.stlThis houses the coils of copper wire and in between of Rotor 1 and Rotor 3.Standard Tesselated Geometry - 183.68 kB - 08/19/2019 at 20:50 |
Stator 1.stlThis houses the coils of copper wire and in between of Rotor 1 and Rotor 2.Standard Tesselated Geometry - 183.68 kB - 08/19/2019 at 20:46 |
Rotor 3.stlLeft side of Rotor 2Standard Tesselated Geometry - 1.39 MB - 08/19/2019 at 20:36 |
Rotor 2.stlMiddle rotor where the left and right housing magnets are attached.Standard Tesselated Geometry - 3.84 MB - 08/19/2019 at 20:34 |
Rotor 1.stlThis is an assembly that acts as a rotor and houses the torsion spring.Standard Tesselated Geometry - 3.77 MB - 08/19/2019 at 20:29 |
Shaft.stlHolds components and hollow at the center to house copper wires.Standard Tesselated Geometry - 540.32 kB - 08/19/2019 at 20:24 |
