The Arduino can be programmed to deliver vapor at different intervals to each chamber. The vacuum suction from the motors enables the JUUL to release vapor. This vapor is carried through plastic tubing into the chambers. There is an adjustable voltage meter if a different delivery speed is required.
Jan Neumann
Films4You
Pierre CHARLIER
Ethan
Hi, could you please tell me more information about the vacuum pumps used for this? Specifically, the type of pumps and where you ordered them from? Thank you!
