Hey, Lex. Awesome design (as usual). It is finding use here at UCDenver! I see two files. Is the slightly updated one just with some material removed for ease of printing? Thanks!
Hi Phil - they are spaced at 1.2mm increments. Each "fin" is 0.6mm thick and each space between is 0.6mm. I forget why I did this instead of 1.0mm, it might have just been easier to print with the spacing a little thicker. The editable design file is here: https://www.tinkercad.com/things/ePmgy8KqMFm, would be trivial to edit to 1.0mm spacing. If you aren't familiar with TinkerCAD I can do it for you too let me know.
