Mouse Brain Matrix
This is an editable 3D design for a mouse brain matrix for neuroscience histology
This will need to be printed at a high resolution with a resin printer of some type:
Editable design is available here!
Standard Tesselated Geometry - 638.75 kB - 11/24/2019 at 18:03
Download
MouseBrainMatrix.stl
STL file for the matrix
Standard Tesselated Geometry - 3.81 MB - 10/10/2019 at 17:13
Download
View all 2 project logs
Phil Durham wrote 09/15/2021 at 19:41 point
Can you confirm that the slice spacing is 1 mm increments?
Lex Kravitz wrote 09/15/2021 at 20:41 point
Hi Phil - they are spaced at 1.2mm increments.  Each "fin" is 0.6mm thick and each space between is 0.6mm.  I forget why I did this instead of 1.0mm, it might have just been easier to print with the spacing a little thicker.  The editable design file is here: https://www.tinkercad.com/things/ePmgy8KqMFm, would be trivial to edit to 1.0mm spacing.  If you aren't familiar with TinkerCAD I can do it for you too let me know.
Lex Kravitz wrote 09/15/2021 at 20:43 point
I'll also throw out that the specific dimensions of the physical part will depend on the printer you use and its tolerance
Lex Kravitz wrote 02/13/2020 at 03:26 point
Hi!  Yup I printed these at WeNext.hk - the white one is Somos GP resin, and the clear one is Somos clear resin.
Derek wrote 09/18/2021 at 08:10 point
Hey there, Is Derek from WENEXT. Our website is www.wenext.com
For any needs, please do not hesitate to contact us.
Cheers
Alfredo Zuniga wrote 01/14/2020 at 15:33 point
Hi There,
Would you be okay sharing what commercial supplier you used to get these printed?
Thanks!
Alfredo
