RES64.logLog of the test results of 330 relaysx-log - 4.22 kB - 02/04/2020 at 23:57 |
RES64.152ok.logVon & Voff of 152 RES64 relays, used to plot stats etc.x-log - 1.87 kB - 11/16/2019 at 23:56 |
banc_test.2.shThe test bench used to measure the hysteresis of the RES64x-shellscript - 3.53 kB - 11/16/2019 at 19:53 |
banc_test.shA first skeleton script for the test bench (uses some external sound files to help with remote operations)x-shellscript - 871.00 bytes - 11/13/2019 at 01:38 |
file_buttons.cThis program captures the /dev/input/mice events and updates the contents of 3 files in real time, for use with a bash script.x-csrc - 3.22 kB - 11/12/2019 at 03:45 |
buttons.casynch. read the status of the 3 mouse buttons and tells if something changed.text/x-csrc - 1.69 kB - 11/19/2018 at 03:15 |
FP23.cfixed point 2.3 ascii format conversion in Cx-csrc - 2.34 kB - 11/18/2018 at 09:13 |
AN3.cconvert between integer and base36 markingx-csrc - 1.35 kB - 11/18/2018 at 08:00 |
octetstream - 1.12 MB - 11/07/2016 at 23:55 |
octetstream - 7.61 MB - 11/06/2016 at 21:24 |
octetstream - 3.12 MB - 11/06/2016 at 21:23 |
octetstream - 422.33 kB - 11/06/2016 at 18:14 |
octetstream - 22.36 kB - 11/06/2016 at 18:14 |
