AMD 2900 Chipset Research
Exploring the 2900 family bit slice chip set.
Looking into the AMD 2900 bit slice chipset gathering information for future microcoded TTL cpu projects.
Working with mondern tools and vintage chips I am looking into the use of AMD's 2900 family of chips. The plans are to extend this knowledge into the design of bit sliced computers.
The first part of this will be to access the functionality of the AM2901 4 bit slice ALU. This 40 pin dip chip contains the ALU section of a CPU.  This chips are designed to work together so you can extend the size of the ALU 4 bits at a time. In the documentation notes on setting up 64 bit ALUs.  When using multiple slices carry operations can be sped up using AM2902 look a head  carry chip. This is the same as what can be done with 74X181 ALUs.
Internally 16 four bit words of dual port ram. This ram is accessed by addressing it through the A and B ports of the chip.  A 1 word scratch pad register Q.  A one word data in port and a one word output port.
There are Up/Down shift functions avalible for RAM and the Q register. A strange quirk of the shifter is that you can shift the RAM address Or The RAM and the Q register.
---------- more ----------
AMD 2900 Family Databook
AM2901A Datasheet
Bit-Slice Design: Controllers and ALUs - by Donnamaie E. White
Donnamaie E. White's web page on the AMD 2900 Family.
Bit Slice Microprocessor Design John Mick and Jim Brick
Part sources * :
B G Micro
Unicornelectronics Under MISCELLANEOUS
Mikes Arcade Under CPUs
TwistywristArcade Under Processors and MISC ICs
*As of last updating. Suppliers list parts with CPUs or under MISC
  • 1 × AM2901B bitslice ALU
  • 1 × Arduino Mega 2560
  • Side Tracked
    Rey Morta06/01/2020 at 05:02 3 comments
    I got side tracked for a bit. I have a 16 bit alu wired up. Its not the most photogentic project. To simplify working I made a stack of PCB board with AM2901 chips. The common signals travel vertically via stacking headers. This still needs fully tested.
    I am still hung up on how I will setup the Microcode seqencer. I have in my possession all three options for AM2909, AM2910 and AM2910 chips. The current issue I am running into is the microcode map (ROM) for using 8 bit instruction requires memmory with 8 address lines and 12 data lines.
    In other news I found a write up via Dangerous Prototype, Ken Shirriff did a post on the internal silicon of the AM2901.  Found here: http://www.righto.com/2020/04/inside-am2901-amds-1970s-bit-slice.html
  • Side Notes
    Rey Morta03/28/2020 at 05:14 0 comments
    Just a couple of side notes.
    Technically the AM2901  can be wired an used as a universal shift register offering both parallel and serial loading along with parallel and serial outputs. It is strangely possible to operate to serial streams shifting in at the same time. You would only be able output one value in parallel at a time. The controlling for this would be slightly akward. It is also possible to work with with this chip as a up/down counter with preload.
    Doing either of these would be both expensiveand a waste of a more functional chip.
  • Day 4
    Rey Morta03/25/2020 at 04:44 0 comments
    Spent some time writting micro op setup for testing chips. I went through my personal collection of chips and they all passed.
  • Day 3
    Rey Morta03/24/2020 at 21:53 0 comments
    More frustrations today. Nothing seems to work when using Port B as a source. I broke down are wrote and made an automated program to scan through the possible 3 micro op combanations to preform:
    Set Ram[0] to 3
    Set Ram[3] to 4
    RegA[0]  + RegB[3].
    I knew from yesteraday that Source 7 (Data port, Zero) ) would allow me to write to ram. The program I set up would clear all of the Ram contents and the Q register Set ram locations 0 and 3 then try every combination of sources and destinations. It would report back if the results matched.
    This did not go well.
    After hours of trouble shooting and chip swapping I found the problem. The 5 volt supply off the Arduino was not strong enough for the AM2901 and was being dragged down to ~4 volts.
    Powering the AM2901 off of a seperate power supply fixed the issue.
  • Day 2
    Rey Morta03/24/2020 at 21:26 0 comments
    One my first day at this I was able to communitcate with the chip and access some of the functioanlities. A lot of this was achived by straight out brute forcing the inputs of the chip and watching the result. While this was time consuming I did confirm functinallity of a few micro ops.
    This was done by setting the function to 0 for add and setting the carry pin high. I would set the source and destination values that I wanted to check with A port and B port 0. Then just pulse the clock. With certain settings this should create a counter. This was charted out on a spread sheet and varifed against the AM2901 data sheet.
    I was able to determin how to read and write to the ram and the Q registers doing this. Functions using the B address port of ram seem flakey.  More brute forcing is envolved.
  • Day 1
    Rey Morta03/24/2020 at 18:50 0 comments
    Wiring up the AM2901 to the Arduino Mega and getting a responce.  To start out I have only wired access to 2 of the address lines for the registers.  The output port from the AM2901B was held enabled.
    Wiring
    MegaAM2901
    2,3
    4,5
    6
    7
    A0,A1
    B0,B1
    Clock
    Carry in
    14,15,16,17Data Out (Y)
    30,31,32ALU Source
    33,34,35ALU Function
    36,37,38ALU Desitnation
    50,51,52,53Data In (F)
    RAM0 to RAM3
    Q 0 to Q 3
    Held HighA2, A3
    B2, B3
    Held LowF output enable.
    Bit order for ports do not follow pin order
View all 6 project logs
Bharbour wrote 06/01/2020 at 23:16 point
There is a book called "Bit-Slice Microprocessor Design" by John Mick and Jim Brick that was a standard book for digital design engineers in the 1980's. It has a lot of information on designing with the AMD 2900 family. As common as it was, used copies should be available still.
Dave's Dev Lab wrote 06/02/2020 at 01:24 point
excellent book! i picked it up a couple years ago!
Rey Morta wrote 06/02/2020 at 01:41 point
Yes,
Actually I have looked through that book a couple times. BitSavers has
a full scan of it available. I'll put the link into my reference section.
Dave's Dev Lab wrote 06/01/2020 at 17:56 point
dandy! looking forward to some insights! i've been reading up on these for a while for my own DIY CPU projects!
