Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
DIY Food Dispenser
I built a food dispenser that serves me the exact amount of 4 different ingredients (Oat, Protein Powder, Chia and Flax seeds).
Elite WormElite Worm
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 8
View Gallery
912
8
14
23
Team (1)
  • Elite WormElite Worm
Join this project's team
completed project
MISC
3d printing arduino display prusa pcb electronics design
This project was created on 04/15/2020 and last updated 8 months ago.
Description
I designed and built a food dispenser that serves me the exact amount of 4 different ingredients (Oat, Protein Powder, Chia and Flax seeds). I used an ATmega328p as the microcontroller and a Nextion touch display. It utilizes 4 micro servo to allow more or less amount of ingredient come out of the containers and a linear type of movement (shake) to avoid clogs.
Details
Log In/Sign up to comment
Sign up with Github
OR
Sarah hossam wrote 04/23/2020 at 09:26 • point
very interesting project. Well done
Elite Worm wrote 05/17/2020 at 10:54 • point
Thank you Sarah!
FLX wrote 04/19/2020 at 05:45 • point
Well done. This is an original method.
I think it only misses a way to adapt regular bottles / food safe containers
Are these shakers working as good as a screw pump ?
Elite Worm wrote 05/17/2020 at 10:53 • point
I haven't had the opportunity to compare it to a screw pump but I'm pretty happy with how it performs.
stefan.schnitzer wrote 04/17/2020 at 10:22 • point
Cool project! How do you measure the dispensed amount of each ingredient?
Elite Worm wrote 05/17/2020 at 10:52 • point
By measuring the weight with the scale.
Dan Maloney wrote 04/16/2020 at 16:24 • point
Impressively complex! I wonder if you fill the legs with some kind of heavy ballast, like plaster - that might help the excess vibration problem. Assuming they're hollow, of course.
Yes! That would be an easy way to get rid of the vibrations... They are almost hollow (20% infill).
Hackaday Prize 2019
This projects converts a Bobby-Car (children's ride-on toy) to electric by using 4 Hoverboard motors, VESC controllers and an ESP32
Project Owner Contributor
Electric Bobby-Car
Peter PötziPeter Pötzi
In 2011, I worked on a prototype head mounted display using two smartphones as display panels for left and right eyes. It used LEEP lenses.
A Smartphone-Based Head Mounted Display
dkrumdkrum
Easy 3D printable seven segment digit powered by 14 WS2812 LEDs.
"pxlDigit" - a 3D printed seven segment digit
FabFab
An upgraded Picture stand with (almost) seamlessly integrated E-Paper
IoT Connected Picture/Desk Frame
Robert PoserRobert Poser
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Food Dispenser", please tell us the reason.
Send message
Remove Member
