Water level alarm for coffee maker
Non-invasive gadget that reminds me to fill up the water tank of my Caffissimo coffeemaker when water level gets too low
I have a capsule coffeemaker "Caffissimo" from Tchibo at home. While the coffee is great, unfortunately it lacks a water level indicator. When there is not enough water left, I don't realize it before the machine starts to make weird noises because it's pulling air instead of water.
Because I'm too lazy to take out the water container and check the water level each time I make myself a coffee, I want to install a sensor that checks the water level and reminds me to refill if it is too low.
I have some Arduino microcontroller and a sensor kit that I can use. I do have a water level sensor but will not use it for three reasons: 1) It's not big enough. 2) I don't want to install electronics in the container or modify the container. 3) It's more fun to come up with something else. Therefore I started with a laser diode and a photoresistor to detect water level underneath critical level.
Basic Idea
Laser diode and photoresistor are placed on the outside of the water tank opposite each other in a way that the resistor is hit by the laser through the plastic tank and water. As soon as the water level sinks, the light refraction through the tank changes and the photoresistor does not receive the laser light. At that point, a visual and/or audible alarm goes off, reminding the user to refill the water tank.
Assembly
I used a battery pack so the system can be run autonomous and turned on/off conveniently. Electronics are attached to the water tank via velcro so they can be easily readjusted or removed. The system is completely non-invasive, the only thing permanently attached to the water tank is velcro tape (adhesive).
Ressources
I used an Arduino Nano to control laser, photoresistor and indicating LED and buzzer. The Arduino code is provided in a Github repository which is linked to.
I soldered the circuit on a perfboard. Detailed circuit diagram can be found in the project files.
Additionally, I made a short video for the project:
Possible Improvements
  • Better fixation of laser LED so it doesn't have to be readjusted after rough handling
  • Dynamic setting of resistance thresholds to operate independent of ambient conditions
  • Allow 24/7 operation by only checking every few seconds and then sending the Arduino to sleep. This would make so you wouldn't have to turn on the battery pack with the coffeemaker.
fzz - 32.78 kB - 05/18/2020 at 22:29
Download
Adobe Portable Document Format - 488.27 kB - 05/18/2020 at 22:28
Preview
Download
  • 1 × Arduino Nano I use Lafvin Nano v3.0
  • 1 × Laser diode KY-008 Laser Transmitter Module
  • 1 × Velcro tape
  • 1 × Plywood, hardwire, screws, adhesives, etc
  • 1 × Photoresistor 2-wire, i.e. GL5539 LDR
View all 12 components
  • Assembly and calibration
    Simon Rihm05/18/2020 at 16:13 0 comments
    I decided to put all electronics (incl. photoresistor and Arduino) on a circuit board. This can be attached to one side of the water tank, while the laser LED will be on the other side - maybe together with a battery pack. Some cables will have to run around the backside of the water tank.
    Circuit Board
    I chose a 30x70 mm² perfboard because I wanted the flat plane I had to attach to the curved tank as small as possible. The photoresistor had to face towards the water tank while the Arduino and most components should face outside, so the board could be brought as close as possible to the tank. This is why I used both sides of the perfboard for components and wiring. I uploaded the diagram to the project.
    Basis and mounting
    I decided to mount the circuit board onto a piece of plywood which I could attach to the water tank. I wanted everything to be removable and adjustable (in order to be able to choose different water levels as thresholds and line up sensor with laser), so I used velcro tape. I put the "hard" side on the circuit board and the "soft" side on the water tank.
    Laser and battery pack
    The laser LED is also driven by the Arduino, so I ran two wires on the other side of the water tank. I wanted to have extra flexibility with laser adjustment so I mounted it with some thick wire on another piece of plywood. At first I thought about attaching this directly to the water tank but since I decided to use a battery pack instead of power line, I glued it to the battery. I attached the battery with the laser on the water tank with velcro tape.
    Calibration
    Two different types of calibration were necessary. After attaching both sides to the water tank, I turned the Arduino on and adjusted the angle of the laser so it would hit the photoresistor through the water. Then, I monitored the resistance values via serial port and changed the thresholds to reflect real-world conditions. I uploaded the code to my Github repository which I link to in this project.
  • Component tests and calculations
    Simon Rihm05/15/2020 at 06:38 0 comments
    Next up, I tested all the components under different circumstances to find out 1) under which conditions to operate and 2) if I could possibly replace them.
    Photoresistor
    I replaced the photoresistor devboard with a standalone photoresistor integrated into a voltage divider circuit. When the photoresistor is "on", its resistance gets very small and most of the voltage drops over the other resistor. If the photoresistor is "off", its resistance gets very large and most of the voltage drops over it. To find out ideal nominal resistor and "on"/"off" thresholds, I tested the resistance under different conditions.
    ConditionLaser 100% intensityLaser 20% intensity
    completely dark
    300,000
    300,000
    fully lighted
    20-50120-150
    through water tank - below water level
    5,000-10,0005,000-10,000
    through water tank - at water level (refraction)
    100-130350-370
    through water tank - above water level (air)
    300-500600-800
    Laser will be operated at 50% intensity at first, but this can be further calibrated. I want to set thresholds for detecting enough water ("on") below 350 Ohms and not enough water ("off") above 1k Ohms. For this, I want to use a nominal resistor of 1k. This way, the voltage thresholds are far enough apart (1.3V and 2.5V respectively) and the resistance is always large enough so only a small current flows (max. 4.5 mA).
    Nominal resistor in Ohms
    3301,0002,0005,000
    "on" voltage (% of 5V)
    51%26%15%7%
    "off" voltage (% of 5V)27%50%33%17%
    difference (% of 5V)
    24%24%18%10%
    max. I in mA
    12.5
    4.52.41.0
    Laser LED
    When Laser Board is "full on" (5V to GND), 29 mA are measured. This means, the nominal resistor on the board is ~120 Ohms.
    With this information, I could rebuild the Laser Board with a standalone Laser LED. I don't have one though and the solder joints on my prebuild board seem sketchy, so I don't want to remove it from there.
    In an attempt to reduce energy consumption, I also tried to replace the laser with a normal yellow LED. This light is not focused enough though and the photoresistor won't detect it through the water tank.
    RGB LED
    I went on to replace the RGB LED board with a standalone 4-end RGB LED and three resistors. I picked 220 Ohms since it is enough to drive the LEDs fully and limits current a little more than the board (150 Ohms).
    Power Source
    I tested powering the system with a 12V battery via voltage input pin of the Arduino Nano. This worked, but then I tested the power drain: The Arduino pulls 50mA on average. This is well below the max. current of the battery (23 A) but will result in very fast discharge.
    The discharge characteristic curve of the battery shows drop below 5V after ~100 hours of discharge with a load of 20k Ohms. The mean voltage during this is 10V, which gives usable energy content of 50mAh. This will power our Arduino only for an hour and even if we can decrease power consumption (don't drive LEDs as hard etc.) will not be feasible. For that reason, I will power the Arduino via Mini USB (wall socket adapter).
  • Proof of Concept
    Simon Rihm05/08/2020 at 12:41 0 comments
    First I wanted to show that the concept I thought of works. To do that, I hooked up the laser diode and photoresistor from my sensor kit to an Arduino Nano on a breadboard.
    Testing components
    I detected the changing resistance when the laser hit the photoresistor and when it didn't. I added a RGB LED and an active buzzer as alarm signals and wrote some code for my Arduino. Now the LED turned red when the laser didn't hit the sensor and green when it did. Changes were accompanied by some buzzing sounds.
    To make things clearer, I changed the buzzing sound to a high-pitched beep when the laser didn't hit the sensor anymore (water needs refill!). When it hit the sensor again (water is refilled), the LED blinks blue three times with electronic buzzing to indicate that everything is OK now.
    Testing application
    Next up, I tested this setup on the water tank of my coffeemaker. Luckily, it worked great! When I position sensor and laser in such a way that the light hits the sensor beneath water surface, it will cease to do so above the water surface. I refined the "ON" and "OFF" thresholds for the photoresistor so that ambient light and dimming of the laser by water and plastic would be compensated.
View all 3 project logs
stefan.schnitzer wrote 05/18/2020 at 16:53 point
Cool sensor design! I could use this instead of the float switch in my coffee machine.  https://hackaday.io/project/14862/log/169624-water-auto-refill-for-endless-coffee-supply
Simon Rihm wrote 05/18/2020 at 23:01 point
Thank you! I was actually surprised, how well this setup works. If you tune the thresholds and have stable lighting conditions, it can probably be even done without a laser, since the photoresistor senses more light through a water-filled tank than an air-filled one. But I guess this also depends on the material of the water tank.
Your Smart Home project is quite impressive though! As a process engineer myself I love the idea of running your house like a production plant with SCADA :-)
