Wandboard experiments
Setting up the WBQUAD
It's hard to find recent (anno 2020) software and information about this 6 year old platform. The purpose of this project is gather the documentation scattered around the internet about how to setup and configure this board.
Some of the information is quite Wandboard specific (setting up wifi-driver), but most of the info will also proof useful on other Linux SBCs.
As some of you might know, setting up a Linux system can be quite challenging especially if your track record on these systems is limited as in my case.
In many ways it's detective work, gathering clues and then putting them all together to find a solution.
This process is time consuming (setting up wifi cost me a weekend of free time) but is very rewarding.
Technical spec of the Wandboard
  • NXP i.MX6 Quad
  • 4x ARM Cortex-A9 @ 1GHz
  • 2 GB DDR3
  • Audio capture & playback
    Christoph Tack08/12/2020 at 14:01 0 comments
    Command line tools
    Installation
    sudo apt install alsa-utils
    Audio playback
    We want to route audio to the line-out.  In order to do that, let's find out what the possible output devices are.
    ubuntu@wandboard:~$ aplay -L
    null
        Discard all samples (playback) or generate zero samples (capture)
    samplerate
        Rate Converter Plugin Using Samplerate Library
    speexrate
        Rate Converter Plugin Using Speex Resampler
    jack
        JACK Audio Connection Kit
    oss
        Open Sound System
    pulse
        PulseAudio Sound Server
    upmix
        Plugin for channel upmix (4,6,8)
    vdownmix
        Plugin for channel downmix (stereo) with a simple spacialization
    default:CARD=DWHDMI
        DW-HDMI, dw-hdmi-ahb-audio
        Default Audio Device
    sysdefault:CARD=DWHDMI
    dmix:CARD=DWHDMI,DEV=0
        Direct sample mixing device
    dsnoop:CARD=DWHDMI,DEV=0
        Direct sample snooping device
    hw:CARD=DWHDMI,DEV=0
        Direct hardware device without any conversions
    plughw:CARD=DWHDMI,DEV=0
        Hardware device with all software conversions
    usbstream:CARD=DWHDMI
        DW-HDMI
        USB Stream Output
    default:CARD=imxspdif
        imx-spdif, S/PDIF PCM snd-soc-dummy-dai-0
    sysdefault:CARD=imxspdif
    dmix:CARD=imxspdif,DEV=0
    dsnoop:CARD=imxspdif,DEV=0
    hw:CARD=imxspdif,DEV=0
    plughw:CARD=imxspdif,DEV=0
    usbstream:CARD=imxspdif
        imx-spdif
        USB Stream Output
    default:CARD=imx6wandboardsg
        imx6-wandboard-sgtl5000, HiFi sgtl5000-0
    sysdefault:CARD=imx6wandboardsg
    dmix:CARD=imx6wandboardsg,DEV=0
    dsnoop:CARD=imx6wandboardsg,DEV=0
    hw:CARD=imx6wandboardsg,DEV=0
    plughw:CARD=imx6wandboardsg,DEV=0
    usbstream:CARD=imx6wandboardsg
        USB Stream Output
    Mixer settings
    1. Run "alsamixer"
    2. F6: select sound card → imx6-wandboard-sgtl5000
    3. Headphone Mux : DAC
    4. Use "Headphon" to set audio output level on line-out.  The line-out setting in alsamixer doesn't control line-out.
    Storing sound settings with "alsactl store" gives an error message.
    Let's play a wav-file now using hw:CARD=imx6wandboardsg,DEV=0 if we would use plughw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav, then the mono audio from the file will be sent only to the left or right channel of line-out.
    ubuntu@wandboard:~$ aplay -D hw:CARD=imx6wandboardsg,DEV=0 ve9qrp.wav
    Playing WAVE 've9qrp.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
    The mono-wav file will be output to the left and right channel of line-out.
    Audio recording
    By default audio will be recorded from MIC_IN.  To record from LINE_IN, the capture multiplexer (mux) must first be adjusted:
    ubuntu@wandboard:~$ amixer -c 2 cset name='Capture Mux' 1
    numid=24,iface=MIXER,name='Capture Mux'
      ; type=ENUMERATED,access=rw------,values=1,items=2
      ; Item #0 'MIC_IN'
      ; Item #1 'LINE_IN'
      : values=1
    After that, recording 5s of audio from line-in is as simple as:
    ubuntu@wandboard:~$ arecord -D default:CARD=imx6wandboardsg -d 5 -f S16_LE -c 2 -r 48000 output.wav
    Recording WAVE 'output.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
    Python
    see Python audio capture & playback
  • VPN
    Christoph Tack06/07/2020 at 18:47 1 comment
    Speed comparison SSH versus VPN
    https://blog.backslasher.net/ssh-openvpn-tunneling.html
    Setup
    Setting up a VPN-server is notoriously hard, so there are some scripts like openvpn-install and pivpn to help you out.
    More details here and here.
    To be able to connect to the VPN remotely, you need:
    1. assign a static IP to your VPN-server
    2. setup an account with a dynamic DNS provider (e.g. https://www.duckdns.org/)
    3. open a port in your router and forward it to your VPN-server.
  • Regional settings
    Christoph Tack06/07/2020 at 18:13 0 comments
    Time zone
    ubuntu@wandboard:~$ sudo dpkg-reconfigure tzdata
    [sudo] password for ubuntu:
    Current default time zone: 'Europe/Brussels'
    Local time is now:      Sun Jun  7 20:11:48 CEST 2020.
    Universal Time is now:  Sun Jun  7 18:11:48 UTC 2020.
    Reboot your device afterwards. Some services (like tor) don't like time zone switches.
  • TUNTOX : Tunnel TCP connections over the Tox protocol
    Christoph Tack06/06/2020 at 15:39 0 comments
    All the info and programs can be found on Github.
    Download program
    • For the Thinkpad laptop running Ubuntu 18.04LTS : tuntox-x64
    • For the Wandboard (running Ubuntu 20.04LTS) : tuntox-armv7l
    Starting the Tox-server on the wandboard
    It's as simple as running that single command.  The shared secret is here "hellohello" (could use something more sophisticated).
    ubuntu@wandboard:~$ TUNTOX_SHARED_SECRET=hellohello ./tuntox-armv7l
    2020-06-06 15:11:42: [INFO]     Tuntox built from git commit 0.0.9
    2020-06-06 15:11:42: [INFO]     Using 11624 for TCP relay port and 50928-50938 for UDP
    2020-06-06 15:11:42: [WARNING]  File not found (/etc/tuntox/tox_save)
    2020-06-06 15:11:42: [WARNING]  Could not open save file
    2020-06-06 15:11:42: [INFO]     Using Tox ID: 6611AA8F892AC73A88C43379C0CA31F1FDA58EED917D970846A43A45BF664966E48678E3ABB1
    2020-06-06 15:11:51: [INFO]     Connection status changed: An UDP connection has been established
    2020-06-06 15:14:51: [INFO]     Accepted friend request from 9E85FB6D952DDE04580E87E5EEBFD46E75DBD322B374D973EA214DF16C8EE3313E4E7AF0A901 as 0
    2020-06-06 15:16:06: [INFO]     Got a request to forward data from 127.0.0.1:22
    2020-06-06 15:16:06: [INFO]     Created a new tunnel object connid=35487 sockfd=8
    Client connecting to the Tox-server
    This command connects to the server and sets up local port forwarding.
    christoph@christoph-ThinkPad-L580:~/Documents/InterestingStuff/remoteConnection$ TUNTOX_SHARED_SECRET=hellohello ./tuntox-x64 -i 6611AA8F892AC73A88C43379C0CA31F1FDA58EED917D970846A43A45BF664966E48678E3ABB1 -L 2222:127.0.0.1:22
    2020-06-06 17:14:32: [DEBUG]	Server whitelist mode enabled
    2020-06-06 17:14:32: [INFO]	Tuntox built from git commit 896775c6089baa24edee06e04f5b83c3bb3bef5d
    2020-06-06 17:14:32: [INFO]	Using 17636 for TCP relay port and 56728-56738 for UDP
    2020-06-06 17:14:32: [INFO]	Connecting to Tox...
    2020-06-06 17:14:40: [INFO]	Connection status changed: An UDP connection has been established
    2020-06-06 17:14:40: [INFO]	Connected. Sending friend request.
    2020-06-06 17:14:40: [INFO]	Waiting for friend to accept us...
    2020-06-06 17:14:53: [INFO]	Friend request accepted (A TCP connection has been established (via TCP relay))!
    2020-06-06 17:16:06: [INFO]	Accepting a new connection - requesting tunnel...
    2020-06-06 17:16:06: [INFO]	Sending packet to friend #0 to forward 127.0.0.1:22
    2020-06-06 17:16:06: [INFO]	Created a new tunnel object connid=35487 sockfd=7
    2020-06-06 17:16:06: [INFO]	Accepted a new connection on port 2222
     In another window, the client can now make a SSH connection on port 2222 which will be forwarded to the Tox-server's port 22.
    christoph@christoph-ThinkPad-L580:~/Documents/InterestingStuff/remoteConnection$ ssh -p 2222 ubuntu@localhost
    The authenticity of host '[localhost]:2222 ([127.0.0.1]:2222)' can't be established.
    ECDSA key fingerprint is SHA256:DsYVUlf605cdhz55Anl14mqYHqnV7ZKEcm4O0xyTaOk.
    Are you sure you want to continue connecting (yes/no)? yes
    Warning: Permanently added '[localhost]:2222' (ECDSA) to the list of known hosts.
    Last login: Sat Jun  6 15:10:44 2020
    ubuntu@wandboard:~$
     Well, that wasn't hard, was it?  The connection seems to be lagging a bit.
  • VNC
    Christoph Tack06/06/2020 at 10:05 0 comments
    I planned to follow this guide.
    ubuntu@wandboard:~$ sudo apt install tightvncserver
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    The following additional packages will be installed:
      libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libfontenc1 libgl1 libgl1-mesa-dri libglapi-mesa libglvnd0 libglx-mesa0 libglx0 libice6 libllvm9 libsensors-config libsensors5
      libsm6 libx11-xcb1 libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-shape0 libxcb-sync1 libxcomposite1 libxcursor1 libxdamage1 libxext6 libxfixes3 libxft2 libxi6 libxinerama1
      libxkbfile1 libxmu6 libxmuu1 libxrandr2 libxrender1 libxshmfence1 libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 x11-common x11-utils x11-xserver-utils xauth xfonts-base xfonts-encodings xfonts-utils
    Suggested packages:
      lm-sensors tightvnc-java mesa-utils nickle cairo-5c xorg-docs-core
    The following NEW packages will be installed:
      libxkbfile1 libxmu6 libxmuu1 libxrandr2 libxrender1 libxshmfence1 libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 tightvncserver x11-common x11-utils x11-xserver-utils xauth xfonts-base
    0 upgraded, 52 newly installed, 0 to remove and 0 not upgraded.
    Need to get 27.5 MB of archives.
    After this operation, 482 MB of additional disk space will be used.
    Do you want to continue? [Y/n] n
    482MB for a VNC-server? Really? No, thank you.
    Vino VNC-server is even worse: 903MB.  x11vnc is also 482MB.  TigerVNC is 483MB. directVNC is 474MB.
    The actual VNC-server is smaller than 0.5GB of course but it needs the graphical environment, which makes up most of the download.
  • Tor
    Christoph Tack06/02/2020 at 20:02 0 comments
    Install Tor
    From ubuntu repository
    Installing from Ubuntu repository is the easiest, but if you want to make hidden services work with authentication, you'll need a more recent version.
    ubuntu@wandboard:~$ sudo apt install tor
    From tor repository
    Add the correct version to /etc/apt/sources.list (see Beginner’s Guide to Tor on Ubuntu).
    Tor key fingerprints : https://2019.www.torproject.org/docs/signing-keys.html.en
    christoph@christoph-ThinkPad-L580:~$ curl https://deb.torproject.org/torproject.org/A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89.asc | gpg --import
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100 19665  100 19665    0     0  61839      0 --:--:-- --:--:-- --:--:-- 61839
    gpg: key EE8CBC9E886DDD89: 36 signatures not checked due to missing keys
    gpg: key EE8CBC9E886DDD89: public key "deb.torproject.org archive signing key" imported
    gpg: Total number processed: 1
    gpg:               imported: 1
    gpg: public key of ultimately trusted key 04C9A9E2D54E852C not found
    gpg: marginals needed: 3  completes needed: 1  trust model: pgp
    gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
    christoph@christoph-ThinkPad-L580:~$ gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
    OK
    christoph@christoph-ThinkPad-L580:~$ sudo apt-get update
    christoph@christoph-ThinkPad-L580:~$ sudo apt-get install tor deb.torproject.org-keyring
    christoph@christoph-ThinkPad-L580:~$ tor --version
    Tor version 0.4.3.5.
    Configuring Tor
    On Beginner’s Guide to Tor on Ubuntu it's explained how to put a password on the control port.  We'll leave the control port disabled.
    SSH login with Tor
    This is explained well in Building a Tor Hidden Service From Scratch.
    If you use this command, you should change the username, the path, the ssh-key and the name of your onion-domain.
    christoph@christoph-ThinkPad-L580:~$ ssh -o VerifyHostKeyDNS=no -o User=ubuntu -o CheckHostIP=no\
    >     -o IdentitiesOnly=yes \
    >     -o ProxyCommand="nc -X 5 -x localhost:9050 %h %p" \
    >     -i ~/.ssh/sshhs1.rsa af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion
    Last login: Wed Jun  3 18:45:01 2020
    ubuntu@wandboard:~$
     It's easier to put it all in ~/.ssh/config of christoph@christoph-ThinkPad-L580:
    Host myOnion
          Hostname af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion
          User ubuntu
          IdentityFile ~/.ssh/sshhs1.rsa
          ProxyCommand nc -X 5 -x localhost:9050 %h %p
          VerifyHostKeyDNS no
          CheckHostIP no
          IdentitiesOnly yes
    Then connection is as simple as:
    christoph@christoph-ThinkPad-L580:~$ ssh myOnion
    Last login: Wed Jun  3 19:01:32 2020 from 127.0.0.1
    ubuntu@wandboard:~$
    Client authentication
    Configuring Onion service version 3 explains how to do it.  On client side, make sure to set the access rights for the ClientAuthDir correctly.
    root@christoph-ThinkPad-L580:/var/lib/tor# ls -l
    total 7936
    -rw------- 1 debian-tor debian-tor   20442 jun  2 21:33 cached-certs
    -rw------- 1 debian-tor debian-tor 2128913 jun  5 20:15 cached-microdesc-consensus
    -rw------- 1 debian-tor debian-tor 5381686 jun  2 22:03 cached-microdescs
    -rw------- 1 debian-tor debian-tor  573384 jun  5 20:25 cached-microdescs.new
    drwxr-sr-x 2 debian-tor debian-tor    4096 jun  5 21:52 client-auth
    drwx--S--- 2 debian-tor debian-tor    4096 jun  5 20:15 keys
    -rw------- 1 debian-tor debian-tor       0 jun  5 20:15 lock
    -rw------- 1 debian-tor debian-tor    7449 jun  5 21:33 state
     /var/lib/tor/client-auth was owned by "root".  That didn't work.
  • Zeroconf
    Christoph Tack05/30/2020 at 13:01 0 comments
    SSH-connections to the wandboard are great, but you need to know the IP-address in advance.  This becomes difficult in networks with a DHCP-server.  It would be easy if you could just call your device by its name.  No matter what IP-address it has.  Luckily in Linux, you can do that.
    Setting your hostname
    The default hostname for the wandboard is arm.  Let's change that to wandboard.
    ubuntu@arm:~$ hostname
    arm
    ubuntu@arm:~$ sudo hostnamectl set-hostname wandboard
    wandboard
    ubuntu@arm:~$
     Reboot the wandboard.
    Establishing a remote connection to the wandboard
    There's no need to know the IP-address.
    christoph@christoph-ThinkPad-L580:~$ ssh ubuntu@wandboard.local
    The authenticity of host 'wandboard.local (192.168.1.8)' can't be established.
    Warning: Permanently added 'wandboard.local' (ECDSA) to the list of known hosts.
    Last login: Sat May 30 12:58:22 2020
    ubuntu@wandboard:~$
    Correcting hosts file
    The Wandboard's /etc/hosts file will still contain the entries for arm.  One of the problems with that is that sudo will not be able to resolve the name.  Every sudo command will take about 30s to authenticate.  The solution is simple.  Open the Wandboard's /etc/hosts file and replace arm by wandboard.
    root@wandboard:~# cat /etc/hosts
    127.0.0.1       localhost
    127.0.1.1       wandboard.localdomain   wandboard
    # The following lines are desirable for IPv6 capable hosts
    ::1     localhost ip6-localhost ip6-loopback
    ff02::1 ip6-allnodes
    ff02::2 ip6-allrouters
  • WiFi
    Christoph Tack05/26/2020 at 19:44 0 comments
    Broadcom BCM4330 driver
    This one uses the Broadcom BCM4330.  Be sure to use the correct firmware-file and NVRAM-file.  These are the ones that worked for me:
    ubuntu@arm:~$ sha256sum /lib/firmware/brcm/brcmfmac4330-sdio.bin
    004eb91ba7f1cd6eaf57b51f90d8004c5663c38175a8a9314a4e2f574cbfbd14  /lib/firmware/brcm/brcmfmac4330-sdio.bin
    ubuntu@arm:~$ sha256sum /lib/firmware/brcm/brcmfmac4330-sdio.txt
    240cb4cbfb37cf516cb6df6373e6fb573ee45e14a22a565bf7d60f42fc40bdd8  /lib/firmware/brcm/brcmfmac4330-sdio.txt
    There should be some logging messages:
    ubuntu@arm:~$ dmesg | grep brcmf
    [   17.644303] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4330-sdio for chip BCM4330/4
    [   17.644638] usbcore: registered new interface driver brcmfmac
    [   17.693124] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4330-sdio.wand,imx6q-wandboard.txt failed with error -2
    [   17.981990] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4330-sdio for chip BCM4330/4
    [   17.982083] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
    [   17.982727] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4330/4 wl0: Oct 25 2011 19:34:12 version 5.90.125.104
    [   19.875155] ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
    [   19.881689] ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
     Don't panic.  The wandboard connects to the AP, even though there seem to be some errors.
    Check that wlan0 exists now:
    ubuntu@arm:~$ ip link
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,DYNAMIC,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
        link/ether 00:1f:7b:b4:11:ef brd ff:ff:ff:ff:ff:ff
    3: wlan0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
        link/ether fc:4d:d4:c5:17:ac brd ff:ff:ff:ff:ff:ff
    Connman
    This is the active command-line network manager.  Tips for practical use can be found on the ArchWiki.
    Just follow the steps to connect to an access point.  Once done, the DHCP-server should have assigned you an IP-address:
    ubuntu@wandboard:~$ ifconfig wlan0
    wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC>  mtu 1500
            inet 192.168.1.6  netmask 255.255.255.0  broadcast 192.168.1.255
            inet6 fe80::fe4d:d4ff:fec5:17ac  prefixlen 64  scopeid 0x20<link>
            ether fc:4d:d4:c5:17:ac  txqueuelen 1000  (Ethernet)
            RX packets 255  bytes 31958 (31.9 KB)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 224  bytes 27296 (27.2 KB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    Pinging and DNS should work as well:
    ubuntu@wandboard:~$ ping -c3 google.com
    PING google.com (172.217.168.238) 56(84) bytes of data.
    64 bytes from ams15s40-in-f14.1e100.net (172.217.168.238): icmp_seq=1 ttl=54 time=30.9 ms
    64 bytes from ams15s40-in-f14.1e100.net (172.217.168.238): icmp_seq=2 ttl=54 time=34.3 ms
    64 bytes from ams15s40-in-f14.1e100.net (172.217.168.238): icmp_seq=3 ttl=54 time=33.1 ms
    --- google.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2003ms
    rtt min/avg/max/mdev = 30.943/32.773/34.295/1.385 ms
     Remarks
    • It's not necessary to install rfkill.  You might be tempted to use it to unblock wifi. but connman handles that.
    • Don't edit /etc/resolv.conf.  Connmand will overwrite it.
    • Don't edit /etc/network/interfaces.  You could add info there about wifi networks, you'd better let that be handled by connman.
    • There's no need to create any wpa_supplicant.conf file as suggested in some fora.
  • Remote Access
    Christoph Tack05/22/2020 at 17:19 0 comments
    How to make a connection from the internet to your wandboard when it's behind a router/NAT?  I see four options:
    1. Reverse-SSH tunnel
    2. Tor as a hidden service
    3. P2P network:
      1. Tox TCP Tunnel
      2. n2n
    4. 3rd party network
    5. Router port forwarding
    6. DMZ
    I'll only handle reverse SSH tunneling here, because it avoids fiddling with your router settings.
    1. SSH Remote port forwarding / Reverse SSH tunneling
    Using Serveo.net almost any port can be forwarded.  In the following example port 22 (SSH) will be forwarded with serveo.net used as a jump server.  It's also explained here.
    Serveo.net might not be up all the time.  Check here.
    This command instructs Serveo.net to forward incoming SSH-connections (on port 22) destined for the alias "wandboard" (the first wandboard in the command) to the localhost (which is the wandboard) (also on port 22).
    The alias "wandboard" in the command is free for you to choose. The following command must be run from your wandboard:
    ubuntu@arm:~$ ssh -R wandboard:22:localhost:22 serveo.net
    Forwarding SSH traffic from alias "wandboard"
    Press g to start a GUI session and ctrl-c to quit.
    Remark that this command will lock up your terminal if you don't add an &.
    If you want to make this connection persistent, you might want to use autossh.
     On your local machine, which could be located anywhere on the internet, you execute the following command:
    christoph@christoph-ThinkPad-L580:~$ ssh -J serveo.net ubuntu@wandboard
    Last login: Fri May 22 17:03:39 2020
    ubuntu@arm:~$
    This command makes an SSH-connection to serveo.net, which in turn connects us through to ubuntu@wandboard.
    Weaved, Dataplicity, ngrokpitunnel offer similar services.  But they require registration and the execution of some sort of script.
    Teleconsole can be used to share terminal sessions between users and port forwarding.  Basically, it's just an SSH-proxy.
    2. TOR as a hidden service
    The disadvantage is that the client side must also use Tor to make a connection.  For more info see Tor project log. Tor is also quite slow.
    3. Router port forwarding
    For connection through cellular networks, this is not possible because you have no access to the router.
    1. You need access to the configuration of your router.  This will most likely only be possible on your own home network.
    2. Each forwarded port must be setup separately in the router.
    3. You might have to assign a static IP-address to the Wandboard.
    4. The additional problem is that you'll probably don't have a static IP-address, so you'll have to use some Dynamic-DNS service such as Duck-DNS.
    5. DMZ
    This fully exposes your wandboard to the internet.  I don't see a reason in taking this risk.
  • SSH
    Christoph Tack05/22/2020 at 15:48 0 comments
    You might also want to try MOSH.
    Checking SSH key-fingerprints
    christoph@christoph-ThinkPad-L580:~$ ssh -o "ProxyCommand nc -X 5 -x 127.0.0.1:9050 %h %p" af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion
    The authenticity of host 'af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion (<no hostip for proxy command>)' can't be established.
    You should only type "yes" after verifying the key fingerprint of the host.  This can be done by typing the following command on the host side.  First check the correct key algorithm and then show its fingerprint.
    ubuntu@wandboard:~$ sudo ssh-keygen -l -f /etc/ssh/
    moduli                    ssh_config.d/             ssh_host_ecdsa_key.pub    ssh_host_ed25519_key.pub  ssh_host_rsa_key.pub      sshd_config.d/
    ssh_config                ssh_host_ecdsa_key        ssh_host_ed25519_key      ssh_host_rsa_key          sshd_config
    ubuntu@wandboard:~$ sudo ssh-keygen -l -f /etc/ssh/ssh_host_ecdsa_key
    256 SHA256:DsYVUlf605cdhz55Anl14mqYHqnV7ZKEcm4O0xyTaOk root@arm (ECDSA)
    Creating SSH-keys
    christoph@christoph-ThinkPad-L580:~$ ssh-keygen -b 4096 -t rsa -C "myKey" -f ~/.ssh/sshhs1.rsa
    Generating public/private rsa key pair.
    Enter passphrase (empty for no passphrase):
    Enter same passphrase again:
    Your identification has been saved in /home/christoph/.ssh/sshhs1.rsa.
    Your public key has been saved in /home/christoph/.ssh/sshhs1.rsa.pub.
    The key fingerprint is:
    SHA256:dBZqUfK7f4L+U36rc7ZPws+uKCJtUihO7fKrS9V4yKg myKey
    The key's randomart image is:
    +---[RSA 4096]----+
    |        o.o      |
    |     o * o .     |
    |    ..=.S .      |
    |   .o.o..  . ..  |
    |  Eo.o o  .. oo .|
    |   .o + + o.oooB.|
    |    o=o= o.o+=**O|
    +----[SHA256]-----+
    Copying SSH-key to the remote server
    You should already have a working SSH-connection for that user on that server to do this.
    christoph@christoph-ThinkPad-L580:~$ ssh-copy-id -o VerifyHostKeyDNS=no -o User=ubuntu -o CheckHostIP=no    -o ProxyCommand="nc -X 5 -x localhost:9050 %h %p"     -i ~/.ssh/sshhs1.rsa af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion
    /usr/bin/ssh-copy-id: INFO: Source of key(s) to be installed: "/home/christoph/.ssh/sshhs1.rsa.pub"
    /usr/bin/ssh-copy-id: INFO: attempting to log in with the new key(s), to filter out any that are already installed
    /usr/bin/ssh-copy-id: INFO: 1 key(s) remain to be installed -- if you are prompted now it is to install the new keys
    Number of key(s) added: 1
    Now try logging into the machine, with:   "ssh -o 'VerifyHostKeyDNS=no' -o 'User=ubuntu' -o 'CheckHostIP=no' -o 'ProxyCommand=nc -X 5 -x localhost:9050 %h %p' 'af66kcmtrfqp6de7wfmfhou5pfrtxqbxtbwpryxl4tuixa5qfe55kkid.onion'"
    and check to make sure that only the key(s) you wanted were added.
    Easy file transfer
    There's no need to use scp over the command line.
    Using Nautilus file manager to transfer files from and to the Wandboard.
View all 11 project logs
  • 1
    Flashing SD-card
    1. Find the device
      lsblk
      NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
      mmcblk0     179:0    0   3,7G  0 disk
      ├─mmcblk0p1 179:1    0    11M  0 part /media/christoph/74C5-8858
      └─mmcblk0p2 179:2    0   3,7G  0 part
      So our SD-card is /dev/mmcblk0.
    2. Unmount its partitions
      sudo umount /dev/mmcblk0p1
      sudo umount /dev/mmcblk0p2
    3. Optional: Clear the SD-card by recreating the partition table. Fdisk will also tell you the sector size.
      sudo fdisk /dev/mmcblk0
      --> o
      --> w
    4. Copy the image onto the device using dd.  When your sector size is 512bytes, you can leave out the "bs=1M" in the following command.
      sudo dd if=./wandboard-all-ubuntu-16.04-sdcard-20160525.img of=/dev/mmcblk0 bs=512 status=progress && sync
    5. Checking file system
      sudo fsck /dev/mmcblk0p2
View all instructions
