Part No. PS11036
Introduction:
Designed for specific application PS11036, by Mitsubishi Electric, is flat base insulated type Power Supply Module, consisting of 3-phase Bridge for AC to DC conversion. IGBT Inverter Bridge for 3 Phase is configured using latest diode and gate technology. PS11036 has motor rating of 2.2KW at 200V AC with Inverter output 100% capacity of 11.0A rms (root mean square) and for 60Sec it can provide up to 16.5A rms that is 150% of its Output.
Following are the main characteristics of the module;
- CONTROL FUCTIONS
- P-Side IGBTs: Drive circuit, high-level-shift circuit, bootstrap circuit supply scheme for Single Control-Power-Source drive, and under voltage (UV) protection.
- N-Side IGBTs: Drive circuit, DC-Link current sense and amplifier circuits for over current protection, control-supply under-voltage protection (UV), and fault output (FO) signaling circuit.
- Fault Output: N-side IGBT short circuit (SC), over-current (OC), and control supply under-voltage (UV).
- Inverter Analog Current Sense: N-Side IGBT DC-Link Current Sense.
- Input Interface: 5V CMOS/TTL compatible, Schmitt Trigger input, and Arm-Shoot-Through interlock protective function.
- MAXIMUM RATINGS
- For Inverter: Supply Voltage 450 V with surge range of 500V, Collector Current for each output at case temperature of 25°C is +/-30A with mean peak Value of +/-60A.
- For Converter: Recommended input Voltage is 220V and repetitive peak reverse voltage is 800V. DC output rated current of 3 phase rectifying circuit is 30A.
- For Control unit: Supply Voltage range is -0.5V to 20V and Fault output current is 15mA.
Application
Application specific inverter and converter package is designed as noiseless motor control module. System has thermal capacity of 125°C max for Junction Temperature and minimum value of -20°C. Module is equipped with Current Abnormality Protection which is achieved by filtering the N-Side DC Bus current. Over Current Protection is deployed with 10 micro seconds when the line current reached the 250% of rated Load Current.
Video on Youtube:
You can get info about more modules or ic chip on our Youtube channel:
https://www.youtube.com/channel/UCnxNgDpzT9kr-cdw1RmhI2Q/videos?view_as=subscriber
