AGH Mechatronics SCARA 2020
Summer semester assignment for 2nd year of mechatronics engineering AGH
This is a complete publication for AGH Basics of Mechatronics class for summer semester 2020. The goal of this class to develop in groups robots using official LEGO Mindstorms & LEGO Technic componetnts in Autodesk Fusion 360. Our team chose to develop a SCARA robot that consists of an arm with 3 dimensional capability of motion.
Our design goals:
We designed SCARA robot with an intention of creating a fully functional mechanism, that is capable of functioning in all dimensions. We wanted to keep the design simple so that our end product wouldn't be unnecessarily complecated, what would hinder its functionality.
Implementation
We settled on a modular approach, dividing the entire device into multiple parts each with a single functionality to fulfill. We decided to settle on the following components:
  • Base - Split into two parts, holds the power supply and a motor that allows the arm to rotate in horizontal axis.
  • Arm - Built using two links, again, each as a separate part.
    • First link - Connects the arm to the base and holds a motor that allows the arm to extend.
    • Second link - Connected to the first link holds a motor that handles vertical movement of the pen.
Each part was designed to be simple, but also stable enough to serve its purpose without any difficulties. This publication contains files for all the components and their assembly below. Technical drawings, containing details and lists of LEGO parts necessary to assemble the robot can also be found below.
Parts
To create this project we used LEGO Mindstorms and Lego Technic parts, detailed list of all parts used can be found below.
FEM Analysis
Current results of both FEM and kinetic analyses can be found in the attached directory or under the following link.
Animation
Operation of our robot is displayed in the following video:
Documentation
The documentation of our entire project can be found among attached files.
AGH_SCARA_Documentation.pdf
Documentation of our project.
Adobe Portable Document Format - 1.83 MB - 09/08/2020 at 14:06
Preview
Renders.zip
Rendered images of our robot
x-zip-compressed - 2.44 MB - 09/08/2020 at 09:11
Download
Images.zip
Directory that holds images of our robot.
x-zip-compressed - 3.78 MB - 08/23/2020 at 17:08
Download
Sub_BaseExtension v4.f3z
Part of robot's base that houses the power supply.
f3z - 3.27 MB - 08/23/2020 at 17:05
Download
Sub_link2 v13.f3z
Second link of the robot's arm.
f3z - 7.46 MB - 08/02/2020 at 11:40
Download
View all 10 files
  • 3 × Lego 53787, Electric Motor - NXT
  • 4 × Lego Gear 24 Tooth
  • 2 × Lego Turntable Large Type 2 Assembly w Outside Gear Section
  • 2 × Lego Gear 8 Tooth
  • 5 × Lego 44294 Technic, Axle 7
View all 42 components
  • 1
    Assembly
    1. Using Fusion 360 models and technical drawings as instructions assemble all the components, using specified LEGO parts.
    2. Connect all components as shown on technical drawings.
  • 2
    Power supply
    Connect motors to the power supply and test the assembled robot
View all instructions
