STM32F pro mini board
The STM32F030 based board with the size as Arduino pro mini has.
I started this project because I didn't find a good replacement for Arduino pro mini on my favorite microcontroller STM32 but in the same size. In revision 6 the board is compatible with "Arduino pro mini" in powering pins VCC, GND, RAW.
Mostly for small projects I use a combination of Arduino pro mini board with AvrStudio (debugging over Debugwire using not cheap ATATMEL-ICE).
But from some time ATmega328P started to not satisfy me in some aspects (not all pins can be configured as external interrupts, poor peripheral, impossible to remap SPI, I2C on other pins and also expensive debugger).
That's why I designed board on STM32 microcontroller that has the same sizes but the reach functionality and cheap debugger.
The MCU of this board is STM32F030K6T6 but it can be compatible with other LQFP32 pack microcontrollers from the STM32 series. For now, tested only with STM32F030K6T6.
Also during producing that board I learned how to design board, how to order PCB on PCBWay China manufacturer, and how to make at home on the cheap CNC router the stencil for easy soldering components. It was a really interesting experience.
For designing schematic and board used a free tool CircuitMaker.
The workspace with all documents STM32FPromini .
Write and compile firmware for this board you can using STM32CubeIDE.
Program and debug using STLink, STlink from Discovery or any China clones.
STM32F_Pro_mini_Rev6.Zip
All files release of the board with revision 6
x-zip-compressed - 1.36 MB - 06/30/2020 at 20:25
Download
STM32F030_Arduino_pro_mini_solder.mp4
Soldering with hot Air process
MPEG-4 Video - 17.05 MB - 06/21/2020 at 10:58
Download
VID_20200621_124253.mp4
Board with flashed firmware blink led
MPEG-4 Video - 429.73 kB - 06/21/2020 at 10:58
Download
View all 3 project logs
Gerben wrote 06/21/2020 at 19:21 point
What toolchain are you using for these?
Bogdan wrote 06/21/2020 at 20:57 point
Hi
Schematic and PCB were designed in CircuitMaker https://workspace.circuitmaker.com/. It is a cloud-based platform from Altium that allows to design of opensource PCB.
The code can be compiled in the STM32CubeIDE https://www.st.com/en/development-tools/stm32cubeide.html  platform for STM32 microcontrollers from ST.
Gerben wrote 06/22/2020 at 18:39 point
Thank you!
