Educational Five-Bar Parallel Robot
Designed to be used as a first robot to introduce students to robotics concepts such as : Inverse Kinematics and control algorithms.
With this planar robot you can play with forward and inverse kinematics and control algorithms.
The second and third version are based on the Teensy 3.2 microcontroller, stepper motors and limit switches.
The third version has two additional holes to attach two incremental encoders connected to the robot joints using timing GT2 belts.
The first  version involves the closed loop control of a DC motor coupled with an encoder and at the same time the kinematics concepts in robotics.
The basic program of the second version uses the teensystep.h library:
https://luni64.github.io/TeensyStep/index
Three libraries are needed to start running the program with the optical mouse:
If you want to control the robot with the mouse (It can be controlled with many other interfaces like touchscreens, joysticks or sending trajectories form a vector)  you need this library:
https://github.com/zapmaker/OptiMouse
The motor driver library (Other motor driers can be used such as L298N):
https://github.com/pololu/dual-mc33926-motor-shield
The PID Controller library to control the motor position in closed loop with the encoder position:
https://github.com/DonnyCraft1/PIDArduino
Educational Five-bar parallel robot_.pdf
Adobe Portable Document Format - 977.06 kB - 11/23/2020 at 10:17
Preview
Five-bar parallel robot V3.zip
Parts of the third version
x-zip-compressed - 1.53 MB - 10/05/2020 at 22:30
Download
Educational Fiver Bar Parallel robot v2.zip
Part files of the version based on stepper motors
x-zip-compressed - 1.00 MB - 08/25/2020 at 12:27
Download
Educational Five-Bar Parallel robot V1.zip
Part files and Mouse control program of the first version based on DC brushed motors and encoder.
x-zip-compressed - 145.60 kB - 08/16/2020 at 10:21
Download
View all 9 components
View all 3 project logs
  • 1
    Version 1: All steps
  • 2
    Version 2: Body assembly
  • 3
    Version 2: Limit switches
View all 22 instructions
babasolomon904 wrote 08/11/2023 at 11:10 point
I trust more people than robots. That is why I choose online writing help from experts. I have to ask professionals to do my math homework and I get valuable knowledge and guidance. https://edubirdie.com/do-my-math-homework is the service that won my sympathy. I like its help and skill to solve quickly any of my assignments. Therefore, I choose wisely between robots and human educational assistance.
Javier León wrote 05/26/2022 at 05:09 point
Very good project!! It would be great if you could add the schematic for the first version
Xavi Cano wrote 10/17/2020 at 15:15 point
Thanks!
Sergei V. Bogdanov wrote 10/17/2020 at 10:57 point
Sergei V. Bogdanov wrote 10/17/2020 at 10:55 point
We have similar project, we describe all the maths https://hackaday.io/project/101683-five-link-mechanism
Xavi Cano wrote 06/24/2020 at 14:39 point
Thanks! I am working on the next version with stepper motors and limit switches!
Dan Maloney wrote 06/24/2020 at 00:18 point
I've seen a lot of these that are very, um... "compliant". This one seems very tight. I'll bet it performs great as a plotter if outfitted with a pen. Nice work.
