Dagor Brushless Motor Controller
Brushless motor controller for velocity and position control with wireless communication.
Public Chat
Arduino-based Brushless Motor Controller for robotics actuators with wireless or serial (UART) communication.
This controller is based on my previous design, the board includes an on-board ESP32, a buck regulator, a DRV8305 MOSFET driver, three current sensing resistors, a magnetic encoder and a temperature sensor. I have tested wireless communication with the ESP32 through ESPNOW and it seems to work reliable and more-than-fast enough without affecting the control sample-time. With ESPNOW you could potentially create a full robot without any single cable aside from power.
Old design: https://hackaday.io/project/173519-janus-brushless-controller-2001
The code is completely open-source and Arduino based. The bulk of the code will be based on the SimpleFOC arduino library, since it has worked perfectly in the past and is constantly being upgraded and updated.
  • 1 × ESP32 Wroom module
  • 1 × DRV8305 Smart MOSFET Gate Driver
  • 3 × TPH1R403NL Discrete Semiconductors / Power Transistors and MOSFETs
  • 1 × AS5147 Magnetic Encoder
  • 1 × LMR14010A 4-40V 1A Buck regulator
View all 7 components
View all 10 project logs
h3nrikmail wrote 8 hours ago point
Very nice project! Can you approximate, how many erpm are possible with an esp32 and the simplefoc library? How fast can the brushless Motor turn?
Xasc wrote 12 hours ago point
Nice, how big current can it hold?
j fer wrote 5 days ago point
Really cool project, bravo :)
For a wire mode, the best option is to use an i2c network with the qwiic connector?
David Gonzalez wrote 5 days ago point
Totally a possibility. There is no i2c slave implementation for the ESP32 in the arduino core as of right now. There's a few workarounds, but I'm not sure how well these behave as I haven't tested them myself.
I was wondering if a quadruped robot with 12 actuators would be manageable with a Raspberry pi and the ESPNOW protocol.
https://hackaday.io/project/161896-linux-espnow
I'm wondering the same. That link you sent me is part of the Solo 8 robot and I believe they don't use ESP-NOW for each individual motor. Id didn't know about the raspberry implementation, thanks for sharing :)
M. Ploegmakers wrote 10/17/2020 at 08:00 point
Well done! Maybe have a look at SwarmDrive, an open source ESP32 based motor driver development board. You can have a look at the code, perhaps it will help you out. See swarmdrive.nickstick.nl
David Gonzalez wrote 10/17/2020 at 18:43 point
Will take a look!
bozkurt13 wrote 10/09/2020 at 15:16 point
PBC'yi paylaşacak mısın?
zhuangfengzi wrote 09/27/2020 at 01:11 point
Well done! I want to be one too! Can you share your PCB?
Waiting for the goods, more your first version! Looking forward to it!
thank!
Owen Williams wrote 08/28/2020 at 09:02 point
I want one.  When do you think yours will arrive? I've read about espnow, wonder how the latency will compare with can bus. E.g for balancing applications it probably needs to be <5ms.
I'd love to study your design files. I've been following your janus and didn't realise you've moved on to dagor.
Is this a jlpcb? What parts will you need to solder?
Simon Merrett wrote 08/28/2020 at 22:18 point
@Owen Williams off the top of my head I recall ESP-NOW taking under 1ms each way. But I could be confusing that timing with NRF24 which is around the same order of magnitude.
David Gonzalez wrote 08/29/2020 at 19:11 point
I haven't done a proper latency test, but I believe for small payloads it should be around 3-4 ms, which in my opinion is totally acceptable for most applications.
Paul Gould wrote 08/30/2020 at 01:57 point
You are correct. It varies between 0.5ms and 1ms for small payloads.
David Gonzalez wrote 08/29/2020 at 19:13 point
I think I will have them on my hand by next Friday. I will have to solder the ESP32, the encoder, buttons and an inductor; I already have all these parts here. I'll try to make sure you get one soon enough :)
Aaron wrote 08/06/2020 at 09:11 point
Nice,so tiny
