Experiment Description: The device terminal will continuously collect light data and uploads it to the cloud for monitoring, and also uploads the status of the current LED (street light). The status of the LED will be turned on and off based on the light value.
For example, the LED turns on when the light value falls below the light threshold we set (at night) and turns off the LED when the light is above the (daytime) light threshold. In addition, the cloud can remotely control the LED light off, to achieve a remote control role.
1. Create RT-Thread Engineering
- Hardware:BearPi
- Software:RT-Thread Opensource IoT operating system
- IDE:RT-Thread Studio V1.1.0
RT-Thread has provides 200+ software packages for developers. In this case we need to use BH1750 package, OneNet package, at_device package, cjson package, webclient package, pahomqtt package.
How to quickly add packages by using the RT-Thread Studio IDE, please refer to HERE.
2. Application Code
2.1 Test the Function.
int onenet_upload_example(void)
rt_thread_t tid;
/* onenet Initialization */
onenet_mqtt_init();
/* Binding led command to respond the callback function.*/
onenet_set_cmd_rsp_cb(onenet_ledcmd_rsp_cb);
/* Create an onenet data upload task. */
tid = rt_thread_create("onenet_upload",
onenet_upload_entry,
RT_NULL,
2048,
10,
5);
if (tid)
rt_thread_startup(tid);
return 0;
MSH_CMD_EXPORT(onenet_upload_example, send data to OneNET cloud cycle);
First, initialize the onenet, the initialization interface is provided on the onenet package.
Then Register a callback function via y onenet_set_cmd_rsp_cb, which is represented by onenet_ledcmd_rsp_cb, and when the led command is issued by onenet, the callback function performs the relevant operation on LED.
Third, create a thread for onenet data upload.
Finally, the function is exported as a command so that we can enter theonenet_upload_example
command on the command line.
2.2 LED command responds the callback function.
static void onenet_ledcmd_rsp_cb(uint8_t *recv_data, size_t recv_size, uint8_t **resp_data, size_t *resp_size)
char res_buf[20] = {0};
char recv_buf[5] = {0};
LOG_D("recv data is %.*s\n", recv_size, recv_data);
if (!strncmp((char*)recv_data, "ledon", 5))
rt_pin_write(SC1_LED_PIN, SC1_LED_ON);
rt_snprintf(res_buf, sizeof(res_buf), "led is on");
rt_kprintf("led is on\n");
else if(!strcmp((char*)recv_data, "ledoff", 5))
rt_pin_write(SC1_LED_PIN, SC1_LED_OFF);
rt_snprintf(res_buf, sizeof(res_buf), "led is off");
rt_kprintf("led is off\n");
else
rt_kprintf("ledcmd ERROR!\n");
/* user have to malloc memory for response data */
*resp_data = (uint8_t *) rt_malloc(strlen(res_buf));
strncpy((char *)*resp_data, res_buf, strlen(res_buf));
*resp_size = strlen(res_buf);
After we receive the command from onenet, the required action is placed here. For example, when our device receives a ledon
string, turn on the LED and print a prompt. Finally, the led is on
message is answered to onenet.
2.3 Uploading data.
/* Upload date to onenet */
static void onenet_upload_entry(void *parameter)
rt_device_t dev = RT_NULL;
struct rt_sensor_data data;
rt_size_t res;
char led_status = SC1_LED_OFF;
char send_buf[32] = {0};
/* Set the pin of the highlighted LED to output mode. */
rt_pin_mode(SC1_LED_PIN, PIN_MODE_OUTPUT);
/* Looking up bh1750 sensor */
dev = rt_device_find("li_bh1750");
if (dev == RT_NULL)
rt_kprintf("Can't find device:li_bh1750\n");
return;
/* Open bh1750 in read-only mode. */
if (rt_device_open(dev, RT_DEVICE_FLAG_RDONLY) != RT_EOK)
rt_kprintf("open device failed!");
return;
while (1)
/* Read a data from the sensor. */
res = rt_device_read(dev, 0, &data, 1);
if (1 != res)
rt_kprintf("read data failed!size is %d", res);
else
rt_kprintf("light:%4d.%d lux\n", data.data.light / 10, data.data.light % 10);
rt_sprintf(send_buf,"%4d.%d",...
Love this idea as streetlights were one of the inspirations for my own project this year ( https://hackaday.io/project/174098-lighting-color-control-with-commodity-lamps ). Bright white streetlight LED conversions are often as controversial as the yellow Low-Pressure Sodium systems they sometimes replace. However I can see using this system along with whatever I'm able to glean from my team's project to offer an LED system that provides a tuned, higher-quality color lighting experience in certain settings and then defaults back to a higher efficiency mode (which may also represent a lower level of color quality but offers benefits to dark sky concerns). Thanks for posting!
