Sygeco
Small console based on attiny85, compatible with tinyjoypad
There are already several "implementations" of the tinyjoypad mini-console, but none was actually open, so I couldn't adapt/play with it. This is my take on it. I also wrote a child-friendly interface to allow for changing the game. You can contact me either through hackaday ("send private message") or on https://www.freehackers.org/thomas/feedback/ All details are given on the official project webpage: https://projects.freehackers.org/sygeco1/
  • 1 × attiny85 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 0.96" I2C 128x64 OLED Display
  • 1 × CR2032 battery holder
  • 1 × CR2032 battery or LiPo version
  • 1 × 5-way joystick
View all 6 components
Thomas Capricelli wrote 01/14/2022 at 13:48 point
Indeed ! That was actually the most difficult part to source.. I got those on aliexpress. You need to search for 'button cap 3.2mm', but even they don't fit all. Those ones on the photo are https://www.aliexpress.com/item/1005001706525334.html
mmryspace wrote 01/13/2022 at 21:24 point
Do you know where I can find a cap with a similar height as the one on the 5-way switch or is it custom? Thank you!
