Nema17 torque after dissasembly
Measure stepper motor torque
See this youtube video for inspiration: https://youtu.be/A4WZm45XJ84 Nema17 motor maximum holding torque was measured, stepper motor disassembled, then re-assembled. Torque was measured again, no significant difference was seen, at most maybe a very small loss (sub 2%).
MotorABC
Winding resistance
3.33.43.4
Inductance (phase A / phase B)
5.1 / 5.1 mH
5.0 / 5.1 mH5.2 / 5.3 mH
Maximum weight at 0.75A (1 phase)176 / 177 g
174 / 176 g176 / 177 g
Maximum weight at 1.0A (1 phase)
218g218g218g
Maximum weight at 1.0A (2 phase)
325g323g319g
Motor disassembled + reassembled 1.0A (2 phase)
320g
Motor disassembled for 24hrs
319g
Weight was suspended 10cm from center of axle.
r = 0.1m
F = 320g = 3.14N
Torque = rFsinθ = 0.31 Nm
Motors are very consistent to their specifications, even though they were built years apart.
  • 1 × MS17HD4420 nema17 stepper motor
  • Motor specifications
    Thomas03/28/2021 at 22:05 0 comments
    Motor PN: MS17HD4420
    4 = 34.3mm length
    weight = 225g (slightly higher than MS17HD4P4100)
    Torque should be about 0.33Nm.
    "420" is the winding current rating but its not clear what this would be, somewhere between 1.0 and 1.5A. Probably closer to 1A.
  • Stepper construction
    Thomas03/25/2021 at 04:45 0 comments
    Internal construction of stepper motor (source):
    Basic Structure
    Known as "hybrid stepper motor".
    Front and rear rotor cup sandwich a permanent magnet, which should hold the magnetic field in the laminations. Perhaps older stepper motors did not have this magnet and were more susceptible to field loss.
View all 2 project logs
Voja Antonic wrote 03/30/2021 at 16:36 point
I like the experiment. I have witnessed dramatic torque loss after reassembly, but I never performed my own experiments. This was interesting to see.
