DIY 3D printable 40% ortholinear keyboard.
Originally made using kbfirmware.com, but has since been ported over to full QMK, and now with VIAL GUI Configurator support.
I mostly made this just to see if a could since I had all the parts on hand. Next I'd like to make a split tented keyboard similar to the orthodex, but with the Cirque capacitive trackpads added.
But for now I'm happy with this design.
Firmware, Freecad project, and stl's attached.
- Initial layout generated in http://www.keyboard-layout-editor.com
- Data from KLE used to generate plate svg in https://kbplate.ai03.com and imported to FreeCAD.
- Plate and housing made in FreeCAD.
- Used the QMK Source/Environment to generate a new QMK firmware
- Then used that to port it to VIAL to work with the VIAL GUI Configurator.
- Extract attached zipfile just goes in the VIAL keyboard folder in their source to generate new firmware or use as an example for your own.
Ticktok
Andreas Känner
Benchoff
Andrey Kalmatskiy
Bo Yao
