• 1
    Remove back cover.
    Just pull from the side indicated by the arrow.
  • 2
    Open it
    Remove battery, memory card and 5 screws.
  • 3
    Detach the screen
    To avoid damage, disconnect the screen, the connector is opened pulling with your fingernail the hinge indicated by the arrow.
    I like to keep it upside down at it's normal position in the front panel, this will keep the screen and front panel free from dust. Dust is a pain to remove afterwards.
