code updated on Github for Arduino 1.8.15 compatibility
07/03/2021 at 04:27 • 0 commentscode updated on Github for Arduino 1.8.15 compatibility.
The problem turned out to be the BLE library uses a lot of memory, so much so when the Webpage, also being served by this sketch, is activated the ESP32 ran out of memory. For whatever reason, this did not turn up when testing with 1.8.14.In any case, the code is now updated on Github to correct for this.
Also, required is the simple patch described here: https://github.com/T-vK/ESP32-BLE-Keyboard/pull/54
updated source after moving to a new computer
07/01/2021 at 22:05 • 0 commentsGot myself a new computer and needed to recompile this project; when I did that I used Arduino version 1.8.15 rather than 1.8.14 as I had in the past. Oddly I started running into memory issues, so I reverted to 1.18.14 for the build. In the process, I also made some changes to the source available on Github for better memory efficiency.
I am also having some Bluetooth issues on my new computer, so if you are trying out this project I'd appreciate your feedback.
entered into contest
06/18/2021 at 02:50 • 0 commentsEntered into 2021 Hackaday contest ( related to Refresh Work-From-Home Life ). June 17, 2021
Youtube video created
06/18/2021 at 02:48 • 0 commentsAs promised in initial release, Youtube video created (June 8) and project updated with its address
3d print uploaded to Thingivers
06/18/2021 at 02:47 • 0 comments3d print uploaded to thingiverse https://www.thingiverse.com/thing:4881425 (June 8, 2021)
Updated YouTube video
06/18/2021 at 02:45 • 0 commentsYouTube Video added (also June 8)
Initial Release
06/18/2021 at 02:43 • 0 commentsThe project was initially released on June 8, 2021
