Comparison with another DIY LISN
08/19/2021 at 19:59 • 0 commentsOverall, without tuning insertion losses to be flatter above 1MHz I would consider this construction as not reliable.
Validation measurement
08/19/2021 at 19:31 • 0 commentsValidation measurements were performed using Vector network analyzer (VNA) Rohde&Schwarz ZNB 8, 100kHz to 8.5GHz. This is my first VNA measurement so please be tolerant. Should I evaluate measurement validity and error sources my guess is that any measurement above 100MHz is invalid due to banana plugs being used. Actually I think that propper LISN manufacturers cheat their validations a bit by having SMA connectors directly in the units and connecting measurement equipment there. For test setups see simulation project log.
Inter channel isolation measurement explains why it is a bad idea to place two channels into same box and why all respected manufacturers don’t do it. There is quite a high amount of crosstalk below 10MHz. This is caused by magnetic coupling of inductors through thin internal wall separating the channels. CISPR-16 requires less than -40dB though, so I consider this unit as fine.
Long story short, after performance validation I consider this home-made CISPR-25 5uH LISN as success and based on measurement results, I release it for hobby use pre-compliance measurements 😊
Assembly
08/19/2021 at 18:17 • 0 commentsWhole LISN was assembled into DIY metal box from solderable metal sheets 1mm thick, 70mm high and 1000mm long (rather permeable and very soft iron). I would recommend to make the box at least 50% bigger to allow greater inductor separation from walls. Reason for this will be clear after validation measurements. Should I build it again, I would create separate housing for each LISN as all the manufacturers do. There is a great reason for it!
Sorry for very bad dimension drawings… this is what is available.
All the parts were cut from sheet using bench scissors and soldered together. This took quite a lot of patience from my wife as quite a lot of solder flux smoke was released across our flat 😊
Air core 5uH inductors
08/19/2021 at 17:32 • 0 commentsInductor L1 has been designed with following online calculator: https://hamwaves.com/inductance/en/index.html#input
Simulations
08/19/2021 at 17:11 • 0 commentsTypically, four basic simulations are performed. This is helpful to understand influence of parasitic properties of electronic components and also helps to identify schematic nodes sensitive to parasitic capacitance to housing etc.
These simulations help to verify that LISN complies to CISPR-25 limits to impedance magnitude and phase angle. Both simulation results are in chart below.
Output impedance simulation with excessive harness inductance from power supply to LISN
Insertion losses simulation
Input to output isolation simulation
It is worth playing with simulation parameters:
- inter-winding capacitance Cpar of inductor L1 which causes decrease of output impedance in higher frequencies and inductor self-resonance which deteriorates input to output isolation.
- parasitic capacitance Cparbnc of signal output to GND which causes steep decrease of output impedance above 100MHz and also shifts a bit inductor L1 resonance frequency.
Schematic
08/19/2021 at 15:18 • 0 commentsSchematic is deceptively simple. Basically CISPR25 circuit with exception of input capacitor capacitance which is 10uF ceramic capacitor in series with resistance 0.5 to 1 Ohm instead of just 1uF capacitor. This is helps to prevent "output impedance out of limits" issue when wiring inductance between power supply and LISN is above 0.1uH. This issue and its solution has been proposed somewhere in the mentioned EEVblog forum threads.
All capacitors consist from multiple units of same capacitance and package to enhance their high frequency properties (less parasitic equivalent series inductance, prevention of resonances and anti-resonances of the capacitors).
R1 actually consists from four 0805 resistors in parallel to achieve above 1W power dissipation rating. Its final exact resistance does not matter while in range from 0.5 to 1 Ohm.
All components (except L1) should be surface mount type to lower their parasitic properties impact to high frequency response.
Intro
08/18/2021 at 18:41 • 0 commentsBuilding 5uH CISPR25 LISN seems like very simple task but evil is in the detail. Without careful evaluation of circuit and housing parasitic properties, it wont pass standard's requirement for output impedance. Furthermore, its unstable insertion losses might render it completely useless.
Hobbyists tent to stuff two channels into single box (like in CISPR-15 50uH LISN used for home appliances), which brings additional issue - channel separation aka cross-talk.
It is not really possible to evaluate the build quality without access to very expensive instruments (Spectrum analyzer with tracking generator or vector network analyzer).
To get true feeling how hard the design and build might be please read first:
https://www.eevblog.com/forum/projects/5uh-lisn-for-spectrum-analyzer-emcemi-work/
https://www.eevblog.com/forum/projects/5uh-aerospace-lisn-how-dumb-would-i-be-to-throw-one-together/
https://www.eevblog.com/forum/rf-microwave/50uh-and-250uh-inductor-design-for-lisn/Also watch amazing video series from FesZ:
Part 1: https://youtu.be/OEvkRW5vZNA
Part 2: https://youtu.be/nq-IhHbZdD0
Part 3: https://youtu.be/M_ab0Oz2ypIAim of this project was to have final working product for daily usage and therefore full testing and its validation across frequencies up to 100MHz is as important as the assembly itself.
Everything is finished, I will soon upload build log with simulations, assembly pictures and validation process.
