automatic axial advance
05/21/2022 at 22:10 • 0 comments -
extra axis for lathe
04/22/2022 at 16:16 • 0 commentsxDD
speaker spider mold
04/20/2022 at 23:14 • 1 commentstarched with cornstarch and heated 30 minutes in furnace.
Now I'm harden it with hairdressing lacquer and pressed on mold again. Lacquer dry quickly.
Next I heat the fabric with heat gun until it smells burnt :)
and then brush a little
trifasic motor frame
04/07/2022 at 21:25 • 0 comments -
reductor
10/11/2021 at 02:09 • 2 commentsTo reduce 1:80 (2.5mm/step)
If I need to change direction maybe I can place an output module with some gears or levers to amplify the movement of last gear (no need as much as 80:1 again) and detect that final tiny backlash.
Or ensure the contacts with springs??
Iodine + Alcohol + graphite to get aglutinant for graphite dust
Let this dry
This aglutinant is serving to me to make some welds where tin can't. It stays very hard and shiny after rubbing with tissue.
And the most important... Stop staining! :D
nice lubrication.
I think now I could even galvanize :D
PCB needle case for 3d printer (ANET A8)
10/11/2021 at 01:53 • 0 comments-
bar case
