ZeroDriver
An Arduino Zero compatible motor driver for robotics projects.
ZeroDriver is an Open Source Arduino Zero compatible motor driver for small robotics and mechatronics projects. Highlights: - Atmel SAMD21 ARM Cortex M0+ microcontroller - TI DRV8835 Dual Low-Voltage H-Bridge IC - RGB LED - Arduino Zero bootloader All the project files can be found here: <a href="https://github.com/electronut/ElectronutLabs-ZeroDriver" target="_blank">https://github.com/electronut/ElectronutLabs-ZeroDriver</a> Crowdfundig now! Please help me bring this project to life: <a href="https://www.crowdsupply.com/electronut-labs/zerodriver" target="_blank">https://www.crowdsupply.com/electronut-labs/zerodriver</a>
Features & Specifications
  • Atmel SAM D21 ARM Cortex-M0+ 48 MHz chip with 256KB Flash and 32KB SRAM
  • Texas Instruments DRV8835 Dual Low-Voltage H-Bridge IC
  • RGB LED
  • Color coded terminal blocks for easy connectivity
  • Standard 10-pin JTAG header broken out
  • SPI header broken out
  • Reverse polarity protection for power supply
  • 12 V max power supply, 1.5 A current per H bridge
  • Shipped with Arduino Zero bootloader for easy programming
View all 11 project logs
