Now published as Open Hardware (OSHW)
10/24/2022 at 01:25 • 0 commentsProject published as Open Source Hardware (OSHW) under CERN OHL v1.2 (Open Hardware Licence).
Source files:
Schematic file
01/12/2022 at 09:06 • 0 commentsHere you can find full PDF schematic:
https://cdn.hackaday.io/files/1827477818647648/PicoBerry_V1.0_Schematic_2022-01-22.pdf
Soldering and bring-up process...
11/24/2021 at 20:34 • 0 commentsIt's time to solder a few boards (missing components - colored pin header + USB-C connector)...
Done! Let's test these boards...
OK, #PicoBerry board is working!
Smallest CM4 carrier board with full 40-pin GPIO header port.
Sorry about the ugly video quality.
https://twitter.com/Mirek34416541/status/1463599187786874887
PCB boards just arrived
11/24/2021 at 20:31 • 0 commentsPicoBerry REV1 boards just arrived!
This time I reduced the PCB pad size for the Hirose connectors to improve soldering and component placement.
...against component floating during reflow soldering.
It should be better now.
